Question about Hotpoint HSS25GFP Side by Side Refrigerator
Fridge and freezer stopped completly. Door of freezer left open
Door of freezer left open all night.  Water all over the floor this morning. The breaker keeps tripping every time I plug it in.  Emptied water from in and out.  Cleaned the inside and back with shop vac...very dirty.  no noise at all.
  • 72 Answers
Let it dry out for a few days, then plug it back in.
Posted on Jun 16, 2009
Kitchenaid kbfs25ewms2 freezer leaking water
Normally I would agree a water line is the issue however on this particular fridge this is not the case. If you open the freezer door, notice the placement of your hand. Unless it is dead center of the handle this is the cause of the problem and what I believe is a major design flaw. Depending if left or right handed, every time the door is opened the metal tracks that hold the door are being bent. If you remove the bottom freezer basket you will notice the back support bar that is attached to the metal rails is not longer straight.What ends up happening is, certain times when the door is pushed closed it seals completely and other times it does not. The times it does not, there is inch gap between the rubber seal on the door and the fridge itself(left or right side). The freezer warms up and items start to melt. As the cycle of freeze and thaw continues you end up with the entire basin full of ice. Eventually when the door does not shut properly and the ice melts it has nowhere to go expect your floor. This is why sometime you will have a pool of water and sometimes you won't but it always leak from a corner. Learned this first hand and ending up ruining 30sq of hardwood floor
Feb 02, 2012 | KitchenAid KBFS25EW (24.8 cu. ft.) French...
Beko fridge freezer left door open all night in error
If the door was left open the fridge compressor would have run without a cut off and so would have resulted in an error. Please shut down the fridge fully remove power for about 6 hours and restart.
Nov 26, 2011 | Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
I have an EB9SHKXVQ refrigerator with the freezer on the bottom. Several times I've noticed a layer of ice on the bottom of the freezer under the basket. I have no idea where the water is coming from....
THE DOOR GETTING LEFT OPEN JUST A CRACK,OR HEAVY TRAFFIC...THE WATER IS COMING FROM THE DEFROST CYCLE. THE HUMID AIR IS BUILT UP ON THE COILS AND THE DEFROST CYCLE LETS IT MELT AWAY. YOU MAY NEED TO REMOVE ALL FROM FRIDGE AND START FRESH WITH A MANUAL DEFROST, USE A FAN THIS WILL SPEED UP THE (ABOUT 1.5HR) DEFROST TIME, WIPE DOWN FRIDGE N FREEZER TO REMOVE ALL MOISTURE, COAT DOOR GASKETS WITH ARMOR ALL, AND MAKE SURE THERE IS NO WAY THE DOORS CAN BE LEFT OPEN, BECAUSE OF SOMETHING NOT LETTING THEM CLOSE ALL THE WAY.. .. HOPE THIS WAS OF HELP.. JAY
Jun 22, 2011 | Whirlpool Refrigerators
Water is appearing under the front left foot (as you look at it). It builds up in to puddle over night. I have checked the instructions which are difficult to follow (not very clear English) but it said...
Freezer drain is plugged.
Two solutions:
1. Call a service repair company.
2. Turn off both controls (turn to lowest setting) and open freezer door for minimum of 24 hours (max 48 hours). That will thaw drain sufficiently.
What has happened: Somehow the freezer drain had ice build-up and eventually froze solid. Every time the unit went into defrost mode, the melted frost (now water) had no place to go. The normal exit is the freezer drain hole which leads to the drip pan underneath. That exit is plugged with ice, so the water went where it could - across the freezer floor and out the bottom of the freezer door. You found it and wondered why.
Mar 20, 2011 | AEG S75348KG Bottom Freezer Refrigerator
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Ice maker stopped working
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Mar 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
331 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
