Too much yellow ink
We have cleaned the printer head 5 times plus and pictures are still coming out with excessive amounts of yellow tone
    Sergeant:
    Champion:
  • 387 Answers
Nozzles may need replacement. I would buy a new printer as they are cheaply priced. Epson.com has loads of them.
Posted on Jun 23, 2009
Stripes in printing pictures in canon ip2700
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Jul 28, 2013 | Canon iP2700 Inkjet Photo Printer
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Canon IP4500 Printer yellow colour will not work even after deep cleaning many times, Pictures come out with pink tone
I replaced the cartridge but not fixed, so I washed the Cartridge holder in warm water still no good, I then soaked the Cartridge ink holder in metholated spirits for two hours and then washed with warm water dried it off and now it works perfectly.
Jun 04, 2010 | Canon Pixma iP4500 InkJet Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printing in yellow tones, all ink cartridges are full and grid pattern ok and nozzles cleaned
Possibly the print head is getting plugged or the color map settings are changed. Try removing the printer and reinstalling the drivers as well as clicking the "default" settings button after. If this does not fix it, possibly the head itself is ok on a test pattern with low ink but on printing is not delivering full ink in all colors, only yellow, indicating the head is plugging. Possibly cleaning with alcohol would help, place a drop on each place the cartridge inserts on the ink tubes and also clean the head surface where the ink comes out with a Q-tip and alcohol and then do a regular head clean.
Aug 29, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Printing problem
lynchfam3 it is problem with the print head so call you can do is print head cleaning and make sure you are using genuine kodak ink cartridge and if still the same issue then try and use the printer in standalone mode i.e try and copy something and check if the image quality is still the same or not if yes then it is print head issue and you need to contact kodak tech support they will replace it for you without any charge.......
Jul 10, 2009 | Kodak ESP 5 Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Pictures coming out yellow
The "Print Head" needs cleaning or replacement. It's the part that delivers the ink from the cartridge tank to the paper itself.Mostly caused by air entering the lines and making any residual ink cure.
Most newer printers only ever use 95% of the available ink before reporting tank is empty,and will not allow any printing to resume, preventing air being introduced to empty lines in the head.
Without Removing Anything
There's commercial products available, I guess a bit like using a head cleaning cassette in your VCR - I Have not tried any of these yet.
Use an empty ink cartridge Refilled with hot water and run the print head cleaning function.
( Dont worry , The paper will absorb the minute amount of water being dispersed.)
If that fails you should remove the print head cartridge most are pretty easy ,
LexMark X1150 X1185 and other similar models with the sensor strip running through the cartridge instructions are located at the following FixYA topic
http://www.fixya.com/support/t181337-piece_fallen_out_printer
Immerse it in warm-to hot water for a while or try using rubbing alcohol or similar Non-solvent based liquid.
Inspect the small rectangle shaped metal print head & surrounding copper track for dried ink , remove any with very gentle wiping taking care not to damage anything.
If it's beyond cleaning it will have to be replaced .Try ebay or the local print shop.
May 12, 2008 | Lexmark X1150 All-In-One InkJet Printer
Hp laserjet Printer
There may be a release lever for the print head assembly which would allow you to remove the print head and clean the excess ink from it. If it appears to get better the more pages you print it may be just a matter of time and lots of pages before it cleans itself.
Try running the print head cleaning utility multiple times to help reduce the amount of ink on the print head. This could take quite a few times before it gets better.
Mar 10, 2008 | HP LaserJet 2550Ln Printer
Ink problem
Hey tootie, the only thing possible are try head cleaning, if it dont work you can buy cleaning cartridges to fix it there only like £5 you will find below. its very common on all newer epson printers. afraid if that dont work its a new printer job as the last time i priced new heads for a epson at trade they wanted £45+vat. All the best John http://froogle.google.co.uk/froogle?q=epson+cleaning+cartridge+c86&hl=en&um=1&sa=X&oi=froogle&ct=title
Mar 06, 2007 | Epson Stylus C86 InkJet Printer
44 people viewed this question
k24674
jasbo
jasbo
