Question about Pioneer Car Audio & Video
Disconection the sound
With 2*150w speakers as loud (jbl limited)when the volume level is on 45 (pionner model 9850)the output is completely disconected.what must be the problem?
This will be a protection feature of the head unit. If you are not using an amplifier, when the power required by the speakers exceeds the power output of the head unit, it will cut out until the volume level is reduced.
If the head unit turns completely off, you may consider adding an amplifier to the sound system.
Posted on Jun 18, 2009
Tip
Adjusting your gain for your amplifier, or amplifiers
I contacted JBL, and Pioneer about the RCA outputs of the DEH-P5800MP. I got a question answered by JBL that you should gain your amplifier, or amplifiers at half of the Head Units volume, in which case the 5800 model has a max volume of 62. I would assume that this goes for any unit since I didn't give JBL the model or brand, which indicates that they are giving a tip on every, or most units unless specified. You can e-mail the manufacture on what unit you have just in case yours is different. I found after a good conversation with the technical support guy at Pioneer that you should turn your volume up to 25-30 (25 for your loudest CD, and gain it from there. I told him that I was an audiophile and he suggested that I could gain it at 45 for my lowest recorded CD. I have been installing and gaining systems at 3/4 volume, or if the max volume was 62 then I would gain my lowest recorded digital CD at that volume. I was amazed that JBL had an answer for probably 90% of the head units, and I have learned something new. I was under the assumption that the higher the volume the more voltage the RCA's put out allowing you to be able to have your amp gain at a lower level. From my experience of 12 years, hearing both companies say roughly the same thing it is apparent that Pioneer units with a 2 volt output should be gained at the 25-30 volume range(probably for your lowest recorded CD. I have CD's that are pure digital and bass CD's and CD's that are recorded louder (like techno music, or alternative music) If you know what you are doing, and can hear distortion, like I can, the tech said that I could gain it at 45 for the lowest recorded CD. This allows your lowest recorded CD to be played at max volume at 30-45, and your loudest CD's would be at peak volume before 30, or 45 if you choose that route. Keep in mind that less power blows speakers before more power does. That is the best advice I can give, and I will adjust my system accordingly to there recommendations. Thank you
on Sep 08, 2007 | Pioneer DEH-P5800MP CD Player
Jbl low volume
The output voltage being fed from your sound card is insufficient to properly drive the speakers. Use more efficient speakers or amplify the output and then feed your JBL's.
Mar 13, 2014 | JBL Jembe 2.0 Speaker System for Desktop,...
Hi I have just got a JBL SCS200.5 BK, 5.1 loud speaker system. I am having the following problem with connecting the loudspeaker system. 1. I have a satellite TV reciever with a single Left, Right &...
I guess you didn't get the owner's manual, huh?
http://www.jbl.com/HI-IN/Products/Pages/ProductDetails.aspx?PID=SCS200.5BK/230
Where are the amplifiers in this scenario?
Page 8: The sub needs a subwoofer Line Level pre-out from an AV Receiver or multichannel processor. Though not elaborated on in the manual, the L and R Line Level RCA connections are probably for use if you lack a Sub Out feed. Running L and R from your receiver would allow the sub to derive a Sub Channel.
The rest of the speakers would connect to the AVR's speaker outputs.
Pasge 9: Alternate method if your eelctronics lacks a volume-controlled sub pre-out. This method routes only the front speaker level power to the sub so it can extract something resembling an LFE channel, then it routes speaker wire out to the front speakers, not as an audio power source but simply as a pathway.
You still need amplifier channels for all but the sub.
Apr 25, 2011 | Audio Players & Recorders
How do i hook up my jbl-jrx112m monitors to my pmp6000 so i can control sound volume,i have sound but only main control not monitors
You have to make a choice... you can tie two main speakers to the "B" channel and the two monitor speakers to the "A" channel.
The speaker configuration slide switch is set to MON1/MONO. The main slider controls the volume of the mains and the MON1 slider controls the level of the monitors in conjuction with the rotary MON1 knobs for each channel.
Each output should not be loaded heavier than 4 ohms. This would be a max of two 8 ohm speakers for each output.
Dec 24, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
Disconecting the sound
the amp kicks out bcuz your pulling to much power out of the amp or your positive wire is to small in gauge.
Jun 17, 2009 | Car Audio & Video
Amplifier Power & Speakers
It's a common misconception that a high-powered amplifier will hurt a speaker when the opposite is more true.
Power ratings are specified within certain parameters at or below certain distortion levels. The problem with UNDER-powered amplifiers is that when they reach for the loudness beyond their clean capabilities they get really dirty and start to distort their output. Distortion will kill even a good speaker faster than a loud clean signal will. Stronger amps run more within their comfort zones and rarely strain for more than brief periods.
In no case should you ever try to do like Spinal Tap in their Mockumentary and turn the volume to '11'. ;-)
The HK's are fine. Speakers are a matter of (mostly) personal preference while amps running within their design limitation don't really sound different so go try out some speakers, see if they'll let you audition them at home and have some fun.
Apr 27, 2009 | Audio Players & Recorders
Just moved a set of JBL Creature Speakers...
nope not with out blowing them too spitherines
Jul 16, 2008 | JBL CREATURE II Computer Speakers
Car Audio & Video Logo
65 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
