Question about D-Link Xtreme N DIR-655 Wireless Router
I try for about 5 hours to connect my book wd 500 gb with the d-link 655 in usb port...WHAT IS THE PROBLEM ???
  • 56 Answers
It could be a firmware issue in combination with a setting on the router.
***WARNING: Even though I state here to do the backup of your settings, I have experienced in the past with my DLINK (DGL- 4300) that it would not restore the backup file, and I had to re-enter all the information manually. If you feel uncomfortable with this, I would either write all the information from your router down, or use some other method to record your settings (like screenshots) OR find someone that is able to reconfigure your network settings if the restore does not work.***
First, I would do to D-Link's Support page and download the manual for this device, it can be found HERE under the Resources Tab. Also, download the latest Firmware, the SharePoint Manual and Utlity (under the Software Applications option) from the same page.
Open up the manual you just downloaded and read the steps on how to backup your routers configuration and then preform the backup.
Once the settings are backed up, I would perform the Firmware update (check manual for these directions also).
Once the update is complete, restore your settings from your backup file.
Then refer to the sharepoint manual about setting up the USB port for the kind of connection that you require,
Posted on Jun 16, 2009
I connected usb port and WD Smart Ware wont start
WD has a program called discovery. It will find the drive for you. Free download.
Oct 26, 2011 | Western Digital My Book Essential Edition...
My WD My Book 500 GB is not recognized by the computer, gets hot and vibrates
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 18, 2010 | Western Digital My Book Essential Edition...
Broken USB connection port on WD 500GB Mybook
I had the same problem and I solved it. Slip off the black case and replace the part thats broken. its cheap. $10 here is the link: http://www.centrix-intl.com/details.asp?productid=9501
I HOPE THIS HELPS!!!!
Jan 11, 2010 | Western Digital My Book Home Edition 500...
NO POWER IN WD MY BOOK ESSENTIAL. THINK THE POWER ADAPTER NOT WORKING MAYBE THE HD IS FINE THERE'S NO BLUE LIGHT THOUGH
May sound stupid, did you try another outlet? Also, you may have to have it connected to a working USB port to get the light to come on....
Sep 30, 2009 | Western Digital My Book Essential Edition...
Please help me Im having a flashing wd book
Try using a different USB cable and port to connect it.
Aug 09, 2009 | Western Digital 500GB My Book World...
Broken usb housing on WD 500 gb my book
You should be able to take out the 3.5 drive that is inside and move it to a new enclosure (does not have to be WD) Tiger Direct has them. You can find them at BestBuy or online for less than $40
Jul 26, 2009 | Western Digital My Book Essential Edition...
Wester Digital My Book 1 TB problems
Try booting your computer first and then connect the usb cable to the usb port on the computer. Connect the power supply cord directly to a wall socket. Also try the usb cable on different usb ports on the computer. If possible also try it with a different usb cable. If nothing works, check the file format system under disk management, you might have to re-format it.
Aug 10, 2008 | Western Digital My Book Essential Edition...
WD My Book Essential Edition 500 GB Exetrnal Hard disk , Intalling problems
dear eVoTech
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
oke
cropp
Mar 18, 2008 | Computers & Internet
WD My Book Essential HD- bad USB port
yes it can be put into a new case check fittings / ide or sata before you buy one
Mar 02, 2008 | Western Digital My Book Essential Edition...
XP doesn't recognize my external 500 GB WD My book essential edition hard drive
Dear karroll.
Im having same as you're problem. but there is solution that might help you, but didnt work for me for some reason..
Best regards
-evo
Nov 27, 2007 | Western Digital My Book Essential Edition...
D-Link Xtreme N  DIR-655 Wireless Router Logo
287 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
