Fault code, CLF, manual restart
I have a Marine Air Systems L2219 unit. I get a fault code that is CLF, = compressor load fault.
It says after three shutdowns you must do a manual restart.
I cant find any information on how to do a manual restart.
    Sergeant:
  • 340 Answers
Try disconnecting power then power bak up should clear it but it all so needs cleaning
Posted on Jun 19, 2009
I have Navegator 2011 air suspension..pneumatic failure.i replace airbag assembly/airlines/Air Compressore still pneumatic failure..what is the cause?
Often the original problem won't go away, even after the repair, until the brain has been told it has been repaired.
When a mechanical or electrical (electronic?) problem triggers a fault code, the fault code remains in many systems until it has been removed with suitable diagnostic equipment.
Jun 11, 2017 | Cars & Trucks
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Aqua Systems water softener isn't using salt when it regenerates. Water isn't being softened. Have manually regenerated three times -- goes through the cycle but water seems to be unchanged. Any troub
check that the small hose to the pickup in the salt tank is not blocked or loose allowing air into the unit rather than the salt water. IT runs on a venturi effect so any air leaks will not allow the water to be picked up. Download the operating manual for the unit as it has a detailed operation including fault finding and over hauling of the unit.
Jul 02, 2014 | Water Dispensing & Filtration
Cf code error of carrier
description: cooling fail action is activated. Action: check compressor operation. turn off main power-restart the unit.
see more: Air Conditioning Fault Codes
Jun 09, 2014 | Carrier 38CKC036 Air Conditioner
Don't understand outdoor self diagnosis code
This sounds like a fault with the inverter or the compressor motor itself,
Nov 26, 2013 | LG Heating & Cooling
The dashborad says suspension fault
Problems with the air suspension seem to be less frequent with the Sport than in previous Range Rover models, but they still do occur. One owner reports "Whenever my RRS is lowered to "access" level a suspension system fault message apprears.". Another reports " Had the RRS back less than 2 hours and another "suspension fault." Also kept receiving messages that the vehicle is raising slowly and vehicle will raise when system cools. Couldn't even drive because it wouldn't raise out of access mode. Anyway, back to the dealer. Picked the RRS up again today-dealer said the EAS compressor was faulty and replaced it. So far everything is ok." Overall, most of the problems seem to be related to bad suspension height sensors or bad compressors. Angus Wade of the Czech Republic had his suspension light come on when in Germany; it started yellow and then red, then disappeared when he stopped and restarted the engine -- and has not happened since. His dealer said they have seen this a bit.
Weak Compressor: An official Technical Service Bulletin (TSB) LS-204-004 addresses "ELECTRONIC AIR SUSPENSION (EAS) WARNING MESSAGE AND LAMP ILLUMINATION". This deals with the warning message "Suspension Fault - Normal Height Only" message appearing with the Air Suspension Warning Lamp on. Computer diagnosis shows pressure increasing too slowly or unable to pressurize, with no air leaks. The usual problem is the compressor exhaust valve sticking, causing an internal air leak when the compressor is active. The bulletin recommends renewing the air compressor (RQG500090 is the latest specification air compressor with a stronger exhaust valve return spring)and installing and updating the air suspension control module software using WDS disc 13 or later.
Suspension Fault Message (random): One owner reported getting random suspension fault messages on his brand new RR Sport purchased in June 2006, well after the fix was in for the weak compressor. His suspension Fault message and Suspension Warning Light (Amber) came on after 5 days of ownership. He stopped and restarted the car, which caused the light and message to disappear, but they came on again after 5 minutes. Later the same day, the warnings disappeared again.
I have heard that on 2006 models, EAS fault messages can be caused by an internal leak in the Air Suspension compressor exhaust valve. The fix is said to be replacing the compressor updating the software.
Hope helps.
Sep 09, 2011 | Land Rover LR3 Cars & Trucks
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Sep 19, 2009 | Heating & Cooling
Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Mar 03, 2009 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
451 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
