Question about Linksys WRT160N Wireless Router
I cant get the router hooked up.
When i tried to hook up the router all of the cables fit except for the one that is supposed to connect to the back of the computer tower. The cable that hooks the tower to the router fits the router, but the other end is too big to fit in the slot in the back of the computer. any help would be appreciated
---thanks for reading
  • nick peak
    nick peak Jun 17, 2009
    i wouldnt know how to install this network card. i dont know how to build a computer. the ethernet cable is too big to fit in the slot that i have now. does anyone have a cable that fits in the modem and in the slot in the back of the tower?
  • 56 Answers
Sounds like your PC does not have a PCI Network card. You can purchase one from NewEgg for <$20, or for a little more your local Walmart/BestBuy etc will have them.
Example of what you are looking for:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2052810027+1128209687+1162810711&QksAutoSuggestion=&Configurator=&Subcategory=27&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Once purchased they are easy to install.
Posted on Jun 16, 2009
  • Jon White
    Jon White Jun 17, 2009
    They use two different lines, your PC has a modem card which has 4 cables, and the modem uses ethernet which uses 8. It is impossible to make a connection between the two.
    To install a network card requires a screwdriver to open the case, and then the card just snaps into a slot. It would come with a simple diagram when you purchase the device.
How to hook up cable box to model tz55x71 manufactured 2000 diagram please
You can Google the model number of the Toshiba for a 'manual" or owner manual which will show your set.
Usually with a cable box in goes to box and out to cable fitting on rear of set and set to channel 3. Output of a box with audio/video cables is same except they connect not to the cable fitting but to the rear inputs on back of set.
FYI most cable companies will come out, connect it and hook it up for little or no charge.
May 20, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
How are cables supposed to hook up in back of router and computer,dlink wbr 2310
You connect an ethernet cable from your modem to the WAN socket on the rear of the router.
Then you connect an ethernet cable from any one of the 4 lan ports to your computers ethernet socket.
If your pc has a wireless adapter, you can disconnect this after you have logged into your router and set the security.
More info here http://www.dlink.com/products/?pid=470
Aug 03, 2010 | D-Link Computers & Internet
Computer wont recognize cable hookup
You will have to start the configuration from the wired network rather than the wireless network. Connect the computer directly to the router. I am assuming you might be trying to configure the router from the wireless network. Then use the installation CD to configure the router
Nov 29, 2009 | Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Belkin N router reads everything but the computer.
If your router was working before, and suddenly stopped working, then you probably need to reset it.
Unplug the router from power, also unplug all network cables from it.
Wait about 30 seconds.
Plug power back in, followed by network cables.
Wait some more seconds while the router restarts.
Only the Power light and the Status light should be solid.
All others in use must be blinking, which means they are in use.
Try connecting to the internet with cable first, then try wireless.
It should work.
Please don't forget to rate if answer is helpful
Jun 22, 2009 | Acer Aspire 5050-3242 Notebook
No internet signal from router in other ports
Hello, Under the wireless menu on router you must give a ssid name and enable and save to turn on wireless , hoe this helps?
Mar 21, 2009 | Linksys Wireless-G WRT54G Router
Link light blinking
On these cable modems the link light is supposed to blink when you are connected to a router/pc. If you are hooking up a wireless router new you need to power cycle/reset your cable modem before you hook up the wireless router so that way it can refresh its ip address.
Mar 21, 2009 | Arris Touchstone 450a (CM450) Modem
DI 624- Cant connect from router to computer
Hi mark - please don't rate this til it's fixed. Hook it up the way you had it. i.e. modem>router>pc. Try it, probably won't work. Unplug the power on your modem and the router. After 60 seconds plug in your modem. When all the lights return to normal (except the activity light), plug in your router. Give it 20 seconds or so. Try it and let me know what happens. Thanks.
Jeff
Aug 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Linksys WRT160N Wireless Router  Logo
440 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
