Question about Dell Latitude C610 Notebook
Dell D600 lcd very dark
The display on my Dell D600 is very dark.  If I look close, I can see the image.  I am having to keep it connected to the port replicator to use it (so muck for being mobile).  Do I need to replace the screen or something less expensive?
  • whtknght Oct 31, 2007
    oops, this is a D610.
    Problem Solver:
  • 20 Answers
Try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Posted on Oct 31, 2007
I have a Dell D600. It starts up to boot page and after 3-5 seconds the picture disappears but the laptop is still running. The indicator light near the power button with a 9 on it stays lit.
I have a similar problem currently. Boot and try pressing Fn+Up arrow repeatedly to raise brightness. Then flick the little button right above your volume control that tells the laptop youve closed it. If you see the screen flicker on/off then its the button. Otherwise reboot and try shining a light at the screen from different angles and see if you can see dark images. If you can see windows boot up but dark, then it is almost certainly your LCDs backlight. If you can't see dark images, next try using the VGA output plug at the back of your laptop to connect to a different monitor. Within less than 1 minute you should see the image on the external screen. If not, try pressing Fn+F8 a few times to toggle the output. If still no picture on the external screen your video card might be fried. If you do get a picture on the external with or without seeing dark images on the laptop, then it is a problem with either the LCD screen, it's inverter, or the screens flex cable. Check Dell support for your systems original parts list HERE. You will need your laptops Service Tag number, which is on a sticker on the bottom of your laptop.
Hope this helps, Good luck.
Mar 06, 2010 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
D600 Latitude laptop - LCD showing ghost/dim images
Connect an external monitor to your laptop and power it up, if you seethe normal Windows images then the video card and laptop is OK and theproblem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dimimage and/or dark display on the laptop's LCD screen indicates a faultyLCD backlight and it could be the inverter that supplies high voltageto the CCFL lamp or it is the CCLF lamp is nearly burnt out or burntout, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Thank you Sir, Have a nice day.
Sep 19, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
Replaced screen computer comes on, but screen stays black.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Mar 22, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 display blacks out, showing just a ghost image
Mar 21, 2009 | Dell Latitude D600 Notebook
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
Loss of light on screen Dell Inspiron E1705
Looks like the backlighting on the display has failed, sometimes it is just a lose cable, buy most often the LCD needs to be replaced.
to check the cable see the manual at http://support.dell.com/support/edocs/systems/ins9400/ for how to get to the LCD cables (usually just under the cover that the power button is on)
Jan 27, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
The screen turns off
REMOVE ALL POWER FROM THE COMPUTER BEFORE YOU ATTEMPT Try this first remove the control plastic panel above the key board,reseat the lcd cable to the motherboard.If no go you may have a loose or bad inverter.Here is how to fix this,REMOVE THE BATTERY,AC CORD.On the front of the display you will see some little rubber covers these cover the screws revove the make sure you put them out of the way,remove the screws remove the bazel.Below the LCD is a little card about six inches called a inverter make sure its snug(CHECK THE WIRE PLUGED INTO IT FROM THE LCD),since you got this apart you might want to look at the rear of the lcd the back panel comes off too but you will have to remove screws as well.THAT CABLE SHOULD BE SNUG AS WELL YOU CAN USE A PIECE OF TAPE TO KEEP IT SECURE.Now thats it for the physical display.Put everything back together and try again.
Good luck
Nov 30, 2008 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Dell Latitude C610 Notebook Logo
146 people viewed this question
Alun Cox
