Question about Polaris 380 In Ground Pool Cleaner
The backup valvue never turns completely off. is this normal
Backup valvue
  • james aurienne May 11, 2010
    are you talking about back wash valve
The backup valve should shut off completely. All the pressure should be going to the Polaris for 3 minutes, and then all the pressure to the backup valve for 35 seconds. If water is coming out of the backup valve when it should be off, then needed pressure to the Polaris is being wasted.
If the Polaris is working fine, then no reason to fool with it. If not, you need to fix the backup unit. You can open it up and clean out debris and readjust it. (You'll really need a "strap wrench" from a hardware store to get off the outer ring. I paid $6). You can purchase the the inside mechanism if you can't fix it. You can also purchase an entire backup valve...outer case and inner mechanism. I bought one for $42 off ebay but they sell for $50-60 and my local pool store quoted $100.
Posted on Aug 08, 2009
Keeps loosing wifi signal
Try resetting your wireless router. Power cycle it through.
Symptoms:
lost Internet access on all devices
unable to go online
no Internet connection on router
router Internet LED symbol is amber
To powercycle your home network:
Turn off the router by unplugging it. If you have a modem and router in one device, turn it off then proceed to step 3.
Turn off the DSL or cable modem for three minutes.
Note: Some modems are equipped with a backup battery. If your modem have one, please remove the backup battery to completely turn off your modem. For common cable modems equipped with backup batteries, please see Performing a full reset of cable modem with battery backup
Turn off all computers attached to your network.
Turn on the DSL or cable modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step. One of the indications that the modem have completed its connection is by seeing a green light on the modem. If you have a modem and router in one device, proceed to step 6 after it connects to your ISP.
Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
Restart your computers.
Jan 09, 2015 | Computers & Internet
How to free a frozen cutoff valve
I would shut off the water and replace it, before it breaks and your ankle deep in water.
May 12, 2013 | Computers & Internet
MY HAIER 1.7 FRIDGE FREEZES ONLY
my trf 285 intergrated fridge freezer has same problem fridge is freezing our food have been informed that a valvue is stuck open the solution
offered was defrost and leave for 2 days i did that it did not work the valvue is not replaceable hope this is some help
Jan 21, 2013 | Haier Refrigerators
My 2002 daewoo nubira,won't start.engine will turned 1/2 way and i can feel like a valvue toching the piston.
Hi, your timing belt has slipped or broken. Would you like instructions for changing the belt? If yes, please verify the engine size.
Jun 19, 2011 | 2000 Daewoo Nubira
When I turn on the steamk valvue the pump turn on for about 30 sec. then shuts off and says ventilate. i just replace the steam valvue today but that was not the problem. can you help?
Check the end of the steam wand for blockage, and or remove the tube feeding the valve and carefully turn machine on and run the steam cycle if no blockage, then remove wand and check for blockage.
May 06, 2010 | Gaggia Titanium Espresso Machine
Whats the best way to back up a laptop?
The best way probably depends on who you talk to. Microsoft includes there own backup programs in all versions except XP Home. (this version the backup is located on the original CD) I prefer to use Acronis. I use this personally and I have all my techs use use. Not only can we do normal backups but the program can do a complete image backup. That's to say if your hard drive went bad after doing a complete image backup then all you would have to do is replace the hard drive and then restore the image and you're back in business. Good luck
Mar 02, 2010 | HP Compaq Presario F750US
The Logo screen freezes on start up.
Connect it to your pc then turn it on. It should either connect or ask you to connect to the pc. If tt home opens shut it down. Do a complete backup of your unit onto the desktop. DO NOT USE TOMTOM HOME TO DO THIS!!!! After doing a complete backup format the drive on your tt useing fat 32. Open tt home and let it reload your os. Do this a couple of times to get the newest os. Disconnect your tt from the computer the way you normally do and restart your tt. Reconnect your tt and do not let home start. Go to your backup and copy and paste your maps back onto the root of your tt. If you have any question email me.
Hope this helps
May 07, 2009 | Tomtom GO 920 GPS Receiver
Snapshot failure
Run the recommended chkdsk and backups still failed after completing the chkdsk w/o error. I than ran Spinrite on the disk which fixed a couple of disk problems. Then ran manual backup which completed without problem. Since the manual backup, the computer has backed up during the normal nightly backup without problem
Oct 17, 2008 | E-Machines eMachines Desktop PC
Polaris 380 In Ground Pool Cleaner Logo
384 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
