Question about Air Tools & Compressors
Unit turns on, goes to 40 psi, quits, motor just hums. Unit's 8 yrs old, infrequently used.
  • 3,230 Answers
A motor shop would be the one to confirm for sure the motor is gone.
If you have and can use an ohm meter you could do a basic test yourself.
You could try to see if the motor windings are shorted to ground.
Disconnect the motor and with the meter set to the highest ohm setting probe the case of the motor and each of the motor leads in turn.
If you get any reading then the motor windings are shorted to ground.
If not set the meter for a low reading and probe the two motor leads.
Should be in the range of 100 ohms or so. If zero while on a low setting then the motor is shorted.
A simple test that sometimes gives you a clue is to smell the motor end of the pump to see if you can detect a burnt odor.
Good Luck!!
Thanks
Posted on Jun 16, 2009
No steam is coming out anymore
hi
it a sign of the pump ceased up or the electric motor faulty capacitor .
check if you can manually turn the pump freely and then check the capacitor
Dec 18, 2017 | Mr Steam Electrical Supplies
My kobalt 80 gallon air compressor won't turn on
BE CAREFUL! Jump the pressure switch and see if it starts. If so, replace the switch. If it doesn't start but hums, cut the power and try to turn the compressor by hand. Free it up if possible. If it does not hum, look for a reset on the motor or a blown fuse or breaker.
Dec 14, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
Ranger rough idle
Vacuum leaks, MAF sensor, O2 sensor, spark plugs, fuel injector, filters and much more.
Apr 25, 2013 | 2002 Ford Ranger Regular Cab
I have a frigidaire wall mounted ac unit. It isnt cooling like it should be and when the motor tries to come on my lights dim and there is a humming noise for just a few seconds before the hum stops. The...
Possible you just need a good maintenance. Clean coils flush and vacuum drain check pressures amps and capacitors change batteries and filter.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 01, 2017 | Frigidaire FAS155K1 Air Conditioner
Whirlpool window unit a/c power comes on but no air comes out
sounds like a bad fan motor or capacitor. mostlikely covered by your warranty
Aug 21, 2009 | Whirlpool ACQ158XP Wall/Window Air...
My shallow well pump will not pump to 40 lbs pressure which is the shutoff setting. tHE MAXIMUM PRESSURE IS 30 lbs so the pump runs continuously. What is the problem ? Pump is Red Lion 1/2 hp series RJS,...
Installed new shallow well pump still only can get to 30 lbs pressure. when i turn pump off pressure drops to 20 lbs right away and stays there
Jun 17, 2009 | Plumbing
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Power on unit hums but does nothing else just keeps humming?
hi there,
stuck up motor,could be capacitor check this out and replace.
could be relay.if defective replace.the motor has star winding after replacing capacitor and humming again,check start winding,if high resistance,replace motor.have a good day,rate me if your satified to my suggestion,thank's a lot
Apr 28, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
