Question about Xerox WorkCentre M128 Copier
Cannot print to Xerox WorkCentre M128 after upgrading XP to SP3
The WorkCentre is setup on our network. Every XP workstation that was upgraded to SP3 will not print to it. If I uninstall SP3 it works again.
So far not much help from Xerox. They can't figure it out either. They installed the latest drivers to no avail. The current solution is to leave one XP machine without SP3. Does anybody have any ideas?
thanks,
Plz tell us how i can remove spanner in my copyer toshiba 2050
Posted on Jun 16, 2009
Download driver workcentre m128 for windows 7
Here you go:
http://www.support.xerox.com/support/workcentre-m123-m128/downloads/enus.html?operatingSystem=win7
May 16, 2011 | Office Equipment & Supplies
Hi, I just purchased a Xerox Work Centre 4118 for my office. I have Windows 7 Professional and am unable to Print via wireless. I receive a message that the Printer is offline. Would you be able to...
http://www.support.xerox.com/support/workcentre-4118/downloads/enus.html
The above links to the drivers page, but unfortunately, I do not see specific Windows 7 drivers for this printer. This means that older XP or the latest drivers from the year 2008 are used in emulation mode, maybe, for Windows 7.
Since this is not a 'new' printer, I gather, it will not guaranteed to work with Windows 7. However, I would try the link above for various drivers which may or may not work on this printer.
The fact that the Printer is shown to be offline, is a bad sign.
I read that the printer in question has the following connectivity:
Connectivity
But, that it doesn't support WiFi.
USB, Parallel, optional 10/100 BaseT Ethernet.
Jan 19, 2011 | Xerox WorkCentre 4118 Network Kit...
How do I change the default tray on our Xerox Workcentre 7328. It won't allow default settings at the moment, and all print jobs are being sent to Tray 1 instead of Tray 4.
Log in as administrator. Press "key" button and enter pass code 1111. You will find the settings quite easily and can change them.
Sep 14, 2010 | Xerox WorkCentre M128 Copier
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Reference: http://4sysops.com/archives/tip-how-to-install-and-uninstall-a-program-in-safe-mode/
Run Windows in safe mode.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Xerox workcentre pro 412 printer do not work
i changed the usb cable to anthor one Parallel Port
Cable so i think the adapter of usb cable is damaged so now it work.
Jul 06, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Xerox WorkCentre M128 Copier Logo
199 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
