1. Unplug the washer
2. Pull the washer out to tilt it back so you can reach the screws below the front panel and remove it. (You will need something to catch the water once the hose is removed from the bottom of washer).
3. Loosen the bolt with the sliver clamp on the bottom of the washer. The water will begin to come out while your loosening the clamp. (Do not remove any GREEN clamps).
4. Once the water is out, you can stick your hand inside the hose to clean it out.
