Question about Dell Inspiron 1525 Laptop
My Dell Inspiron 1525 will not power up at all. The adapter works, however the battery is dead. The battery stopped charging about 6mos. after I purchased the unit. I did notice that where you plug the power adapter in at is loose. I don't know it it is pushed inside the computer too far or if it has just burnt out or whatever. I had this computer exactly 1yr and 1 day. (of course, 1 day past the expiration or the warranty). Thanks in advance for any answers.
  • Audra Jun 16, 2009
    The charger is plugged in to the unit. It is totally dead plugged in or not.
  • 23 Answers
I had the same problem... there can be a few reasons why... the adapter i had was at first able to charge the battery... for some reason it stopped charging the battery but was still able to keep the power on... i had a friend who also had a dell laptop and for some reason his adapter was able to charge my battery so it wasnt the battery... i called dell and they sent me another adapter and that was able to charge it...
Posted on Jul 10, 2009
  • arronmccoy Jul 22, 2009
    also sometimes it could be a motherboard failure.... which dell will happily replace if under warranty... when starting up your computer press F2 until you come to bios... check your battery info... if it says unknown adapter and battery is fine... then it prob is the motherboard...
    Problem Solver:
  • 7 Answers
Just keep the charger on.
Posted on Jun 16, 2009
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
I have an Dell Inspiron 1525 and its battery isn't getting charged.The battery gets charged every now and then but mostly,the laptop runs on AC power without getting charged.It gives me the message...
if it is the original stuff used...and nothing is changed..then try to install the battery driver so that it will be able to recognize the charger ..o r...you will have to get a new battery cause this one might be dead!..(you may take in counting a bad contact ...but if the battery works by itself when it does charge...it means that its not a contact problem ..but just a new battery needed...)
Jun 26, 2011 | Dell Inspiron 1525 Notebook
Laptop will only work when plugged into the mains, battery will not charge
your battery may be died or discharged comptletely and your power adapter are not charging.
get test the power adapter first, if it is ok, you should buy a new battery then
otherwise you should buy a new power adapter.
Aug 18, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Plugged in not charging is what my inspiron 1525 is telling me and i dont know what to do to fix it. i cant unplugg it cuz it dies imediatly can you help me?
If your dc-adapter is a Dell original, that means your battery is dead and you need to replace it. However, if your adapter is a generic model, most Dells would work with one but will complain, although with a different phrase than yours. So, odds are it's the battery. No gimmick to fix that one other than getting a new one. Sorry.
Sep 09, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Laptop Logo
993 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
