Reset Code for Nashuatech 2205
how to reset the consumable count of Nashuatech Model 2205 when the drum is replacing.
  • 204 Answers
I'm not sure what do you mean i f you mean how to disable the consumable alarm you can do it by the follow step:
press the yellow [clear mode] key, than press the follow numbers 1-0-7 and than press and hold the red key [cancel\stop] until on the screen do not appear the service mode. When the service mode will appear press [copy sp] on the touch screen, then press [5.mode] on the touch screen and press [next] on the touch screen until you come to [5-507-001] ;[5-507-002];[5-507-003] and follow there you need to change the consumable alarm than you want by putting "0" in place of "1".
Posted on Jul 11, 2009
How do I reset a drum from user mode?
This is simple. You can't. Manufacturers make their money from consumables. They don't want you to be able to reset anything to get more life. The drums have internal fuses that blow when put in the machine, that's how they reset the counts. Sorry.
Apr 25, 2015 | OKI C9650HDN Led Printer
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
How to reset DCP 7030 drum unit
Reset DCP 7030 drum unit : -LCD-
Press MENU and turn on printer - MAINTENANCE
arrows 81 and OK -RESET DRUM COUNT
press OK -RESET LIFE COUNT
press CLEAR / BACK
arrows 99 and OK
ready
Oct 26, 2009 | Brother DCP-7020 All-In-One Laser Printer
OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Oct 14, 2009 | Oki Electric Industry C8600n Led Printer
How do I reset the page count on a HP Laserjet 4345mfp? Cheers Michael
the total page count cannot be reset, if you wish to reset consumable counts replace relevant consumable. thanks
Oct 05, 2009 | HP LaserJet 4345mfp Printer
Brother 8360p says change drum soon
You have to open the front door and then press options, should see Replace Drum? just answer yes.
Sep 09, 2009 | Brother MFC-8440 All-In-One Laser Printer
B&W Xerox copier XC23 has code J7 and will not print
There is a chip on the back of the drum unit that keeps count. It cannot be reset. You may try to find a replacement chip on the internet. I would recomment the rechargerstore.com They have good products. I do not know how long your drum will last, you may end up having to replace it for copy quality problems at some point.
Feb 28, 2009 | Xerox Office Equipment & Supplies
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
Reset code 2205 of oce 7051
for what model do you speak me and no body else can't help you if you do not name the machine brand and model
Dec 24, 2008 | Office Equipment & Supplies
Were is the drum cartiage located in the m128, says its not inserted right
You have to open the front cover and the left side door to access, it is located inside the front cover on the right sife of the machine.
You have to unlatch it and re insert it .
Dec 11, 2008 | Xerox WorkCentre M128 Copier
118 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
