Question about Sony Televison & Video
Banding on screen
Hi we have a sony bravia kdf50e2010. We have for the past few weeks had a band appear across the top of the Tv and more recently two other bands one in the middle and another across the bottom. They arent any particular color as the change depending on colours of program. We thought it was possibly the bulb but are now not sure. There is no warning light on the Tv regarding the bulb. Any ideas beofre we go out and buy an expensive bulb.Thanks Louise
  • coley11 Jun 17, 2009
    sorry i didnt mention it isnt a new tv its about two years old and we have no warranty on it.
  • 92 Answers
Since this TV is still new, it's much faster if you exchange the unit at the place of purchase and get a new one. You can also call Sony at 1-800-345-7669 (SONY) and get it service for free.
Posted on Jun 16, 2009
  • Tony Nguyen Jun 17, 2009
    hi Louise, sorry about that. Do the line happen on all inputs? does it moves when changing channels or it's stationary?
My sony bravia 32" is
hi ;
there's a problem in screen driver of your LCD, if you lost your receipt,that's bad luck.
if you know how to disassemble the back case of the TV , you can try some RESETTING of connectors from LCD screen driver to display driver board
its only 50% chance to remove the line.
thanks.....
Sep 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
InFocus LP600 - A vertical shadow on the Left-side covering about 20% of screen.
The light tunnel inside the "engine" is either out of alignment or the glue holding the tunnel together is coming unglued and 1 of the 4 sides has fallen in. There are 2 screws to adjust this if the tunnel is still intact. One or both screws can be accessed by opening the lamp door and then you have to remove a thin sticky cover. You will see 2 small screws that will have to be adjusted with a small torx (3) or allen. You will have to have the safety switch pushed in with something and adjust while the projector is on, using the most easily accessible screw, turn it towards the direction of the "banding". It should decrease. If not, turn the screw the other way. The screw that is not so easy to get to is for adjusting the banding the can appear across the top or bottom of the screen. If the banding gets worse or even starts to show diagonally across the screen, it is a good bet that the tunnel has collasped.
May 03, 2010 | InFocus SP-LAMP-019 Projector Lamp for...
SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Jan 20, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Grey vertical line appears on screen
I had the same problem with my Lnt4071f. I called tech support and they said it was a faulty panel and the entire set had to be replaced. If you have your warrantly still use it, if not you may just be able to replace the panel, but its expensive.
Dec 27, 2007 | Disteck P4204TWHD Television
Banding on LCD TV
you need a new motherboard
Dec 09, 2007 | Televison & Video
Lines across screen
Is it sort of rolling almost.
If so you have a few bad capacitors in the power supply that need to be replaced.
If you dare to venture inside you should see 1 or more buldging caps. (bowing upwards on the top)
If these start to fail, then they will interupt the correct flow of power and cause this problem with your panel.
Easy to fix if you are electronically minded, if not, take it to your local TV tech and it shouln't cost that much to have repaired.
Remember, inside these monitors is high voltage that can kill, even if it's not plugged in.
Dec 10, 2006 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Televison & Video Logo
198 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
