Question about Apple iPhone Smartphone
Slider does not move
When I recieve a call soemtime slider does not move at all as if it is jammed or locked.
  • 25 Answers
Your screeen has either been sat on or something and the touch screen cant sense any other thing except the pressure on in. try smackin it gently NOT bangin try that and see if it works
Posted on Jun 16, 2009
4690 MF Printer displays the following message:"SCANNER MOTION ERROR, CHECK SCANNER LOCK"
I would open up the scanner and check to see if it can move, When you turn on the machine does the scanner try to move before the code shows up.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 18, 2015 | Konica Minolta Office Equipment & Supplies
Memory card is saying locked
There's a little slider on one side of the card with 2 symbols (open and closed pad lock). Move this slider to the open pad lock position - that will unlock the card.
Hope that helps
Aug 02, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
It keeps saying card locked when i push the red button
A locked card is usually caused by the little slider on the side of the card. Move the slider to see if it solves the problem.
Jul 01, 2010 | Cameras
I cant take delete, or move photos from my sd card, If i try to do anything with the images on the card when its plugged in to my computer a pop up comes up saying 'Cannot move 4267_180627790516_589680516...
is the card lock slider on? look at the card, there is a tiny switch that says in tiny letters lock, is that moved to the lock position? the little slider is on the left side of the card with the SD Logo label
May 07, 2010 | PNY 2GB microSD Memory Card
Acer aspire does not open
Do you mean that the lid doesn't open or that your operating system doesn't open? If it's the lid, then the latches attached to the slider are jammed up. You can force them back with a small flat-head screw driver or a butter knife, or some other thin object that you can slide in there. Be careful not to scratch your LCD with whatever it is that you choose to use to open the lid. Once you get it open, move the slider back and forth to see if the latch hooks are moving with it. If they are then there is something going on with your lid that is preventing them from moving back after it's be closed. Sometimes this is due to the lid being slightly bent so that it causes the latches to lock in tightly and then not move back to unlatch when moving the slider. If you were meaning that your operating system won't open then you may need your system reinstalled. MADHATTER COMPUTERS
Mar 22, 2010 | Computers & Internet
How too change the ignition switch on a 88
disconnect negative battery cable.place the ignition lock in the off lock position. remove the 2 switch mounting screws.disconnect the switch from the rod.disconnect the wiring and remove the switch.TO INSTALL.ignition switch installation for non tilt columns.move the the ignition switch slider to the off unlocked position move the slider all the way down.then back 2 clicks.the remote rod hole in the ignition switch slider should now be centered.insert the remote rod in the ignition switch slider hole and install the ignition switch on the steering column.tighten the attaching screws to 35 inch lbs.ignition switch installation for tilt columns.insert the ignition key in the lock cylinder and turn the cylinder to the off unlock position.move the ignition switch downward to eliminate any slack and tighten the attaching screws to 35 inch lbs.
Nov 26, 2009 | 1988 Jeep Cherokee
I need removal and installation instructions for the ignition swith
GM Buick/Oldsmobile/Pontiac/Full-Size 1975-1990
Repair Guide - Ignition Switch
CAUTION Do not attempt any service on the steering wheel, column or instrument panel on Buick and Oldsmobile models equipped with an air bag. Service on these models should only be performed by a professional technician.
REMOVAL & INSTALLATION
  1. Turn the steering wheel so the vehicle's wheels are in the straight ahead position. Turn the key to the LOCK position.
  2. Disconnect the negative battery cable.
  3. Remove the column to instrument panel trim plates and attaching nuts.
  4. Lower the column and disconnect the shift indicator cable.
  5. Disconnect the ignition and dimmer switch connectors.
  6. Remove the switch attaching screws and remove the switch.
To install:
  1. Move the actuator rod hole in the switch to the lock position.
  2. Install the switch with the rod in the hole. Adjust the switch as follows:
    1. Models to 1988- Move the switch slider to the extreme left ACC position, then move the slider 2 detents to the right to the OFF-UNLOCK position.
    2. 1989 and 1990 - Place a 3/32 in. drill bit in the hole on the switch to lock the switch into position. Move the switch slider to the extreme left position then move the slider 1 detent to the left LOCK position.
  3. Position and reassemble the steering column in reverse of the disassembly procedure.
I hope helped with this (remember rated this help) Good luck.
Nov 18, 2009 | 1989 Oldsmobile Custom Cruiser
Why is my memory card locked? How to rectify and delete pictures
Hi Aruna_Devana,
When you say locked do you mean "write protected?" If you look on the left side of the card there may be a notch in the card and a slider. Move the slider forward to cover the notch and you should now be able to use the card. If the slider moves back to 'lock' when you insert it into your camera, put on a bit of sticky tape, just enough to hold it in place, being careful not to cover any contacts on the card. Hope this helps.
Mark.
Mar 10, 2009 | Canon IXUS 960 IS Digital Camera
Bottom Draw Wont Close
Check the sides of the drawer on the dishwasher and make sure that the sliders that the drawer rides on are not locked in place you will notice on the front of the slider near the door panel there are plastic clip like press in tabs that hold the drawer securely in the tracks try to put your hand up under the door and move the track if the track moves in the slider you will need to hold the door secuely with one hand while sliding the track to the most open position on the slider track. if the sliders are not locked in you will be able to pull the slider forward and the slider should clip into place.Repeat this for both sides and the door should operate like new once again.
Jan 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Apple iPhone Smartphone Logo
111 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
