Question about Weslo Cadence CT 4.8 Treadmill
My treadmill goes at a normal speed when no one is on it. However, As soon as I start walking it slows.
  • Anonymous Mar 31, 2014
    Schwinn treadmill 5210p motor comes on and operates, will go up to 10 mph and back down to 0 mph. at 4 mph or whatever speed, as soon as you step on the deck to start to walk the motor quits.
  • 4 Answers
This is normal operation due to putting weight on the belt. Set your final desired speed after you start walking.
Posted on Jun 16, 2009
    Problem Solver:
  • 4 Answers
I saw that, is the motor, remove motor and send to check electricaly, internal a coil can be in anormal state.
Posted on Nov 05, 2009
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
My walking machine is running really slow and the mat is going side to side when we are running
my walking slows down when walking close to top and speeds up closer to the bottom of the treadmill.
Feb 11, 2013 | Sportcraft Exercise & Fitness
My treadmill work fine when i turn it on but when i step on it the blet. slows down to crawl.
What make/model is the treadmill? What speed does this behavior occur? Does the walking belt slip, while the motor and rollers continue to turn? If the walking belt is slipping then the motor belt needs to be tightened. If the walking belt slows with your weight on it, does this happen at 1-3 mph and still occur at 4-5 mph? It could be your body weight causing it to slowdown, try to increase the speed to 4 or 5 and see if it still happens. If so, is the treadmill rated for your body weight? Please be more specific.
Feb 08, 2011 | Exercise & Fitness
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Jul 30, 2009 | Proform CrossTrainer Treadmill
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Jul 14, 2009 | Exercise & Fitness
Treadmill goes normal speed until I get on it and then it slows down
When was the last time you placed the correct lubrication between the walk belt and the walk board. This is a very common issue. Make sure you DO NOT use anything from an aerosol can. The acetone will cause the belt to get dry, hard and crack.
Good luck.
Jun 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
My treadmill will go normal speed set at until you start walking on it and then it slow way down. Why would it do that?
Try looking for a problem in the power.if that doesnt work,send it to a technician or if you had a warranty on it even better.
Jun 15, 2009 | Nordic Track NordicTrack Treadmill, A2550
Weslo Cadence CT 4.8 Treadmill Logo
662 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
