Question about Microsoft Xbox 360 Console
I am using a Netgear WPN824v3 wireless router and attempting to connect to XBox Live by directly connecting the console to the router. It gives an error message saying I have insufficient MTU settings, and that they need to be 1364 or higher. When I checked on my router settings page, it is set at 1500 MTU. Help please!!!!
  • 24 Answers
XBox Live is down today June 16th, 2009. It won't be back up until either late tonight or early tomorrow.
Posted on Jun 16, 2009
2 Suggested Answers
SOURCE: cant connect to xbox 360
its gettin fixed to day, so its shut down everyware but should be on tomora
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
I tried to connect Netgear Wireless Router WPN824v3 to my Compac Presario CQ60 Notebook using the installation CD provided with router. After connecting all required cables and reapplying power to modem...
Try connecting a cable directly from your router to your laptop and using the actual IP address of your router instead of routerlogin.com, being a Netgear it should be 192.168.1.1 or 192.168.0.1.
Hope this helps.
Nov 13, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cant connect to xbox 360
Jun 16, 2009 | Microsoft Xbox 360 Console
I need to open my NAT type for xbox live
You can contact NETGEAR support to help you open the NAT settings. ( they know how to do it )
Note:
The simplest way and most efficient way to connect to xbox live is using DIRECT MODEM CONNECTION
For compatible list of devices and internet service provider, please check the website ( www.xbox.com )
Apr 14, 2009 | Microsoft Video Game Consoles & Games
Xbox has been connecting no problem via netgear router. Suddenly it has stopped and cant go live any more. Dont know how to work out if it is xbox wireless adaptor or netgear router.
Do you have any other computers or game consoles hooked up the netgear router? if the other computers etc. can connect to the Net via your router, then it sounds like your Xbox adaptor might have failed.
Apr 04, 2009 | Microsoft Xbox 360 Console
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
Xbox live connection keeps crashing.
problems usually happen, when the signal strength drops.
I,d suggest hard-wiring the 360 to the PC or router, for optimal performance.
Thankyou for using fixya.
Mike @ compurepair.
Jan 05, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
515 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
