Question about GE Spacemaker JVM1640SJ Microwave Oven
Over the range Microwave trouble
My over the range GE microwave is two years old, and all of a sudden started acting strange.
When I open and then close the door it starts working on its on. If I try to stop it by pressing "Clear" it won't stop, and while it is working the clock is showing just the clock time, not the cooking time.
I have to press several buttons to get it to stop working.
  • Anonymous Mar 15, 2014
    First time we plugged GE microwave in it started. Pressing Cancel does not clear for new selection
It is a door switch problem of some sort.  I have two Sharp R-1611 units that do the same thing.  The light and fan come on, but not the heat, thank goodness.
I am going to replace it since the plastic for the case and door is cracked in numerous places.  I have spent several hours researching microwaves online have not a single clue what to replace the Sharp with.  Seems like every vendor has very good units and very bad units.  I guess you just pay your money and take your chances.
Posted on Nov 01, 2007
GE microwave suddenly stopped. Plug is OK, fuse not blown. Is there a way to reset?
No! if your microwave oven is 7 years old or less it will most likely have a inverter board that often causes trouble, or the keypad control board is defective.
May 17, 2012 | GE Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I have a GE Profile XL1400 over-the range microwave which is about 12 years old. Suddenly yesterday morning the microwave would not cook the food. It turns on and runs just as it normally would, but the...
At the ripe old age of 12, the magnetron tube which makes the microwaves has most likely failed. A sudden no-heat condition is one of the most common ways they go. It's possible to replace the magnetron, but it would be an expensive repair. The tube is the most costly part, and this repair is one that should be left to a professional because of safety concerns. Between the part cost and labor, it usually more economical to replace the oven with a new one.
It is possible that something else is causing the problem, such as a failure of the control circuit board or the high-voltage power transformer. It's still not worth the repair since the 12-year old magnetron would be a failure waiting to happen. Take this opportunity to start fresh.
Nov 28, 2010 | GE Microwave Ovens
GE Microwave stops running
Mostly with GE I find this to be bad connections at the fuse holder or a bad fuse due to a bad fuse holder. It will break connection and reset the unit when the connection gets hot and expands and then opens and stops power from getting to the unit.
Aug 14, 2017 | GE Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave won't shut off
The door switches are what tells the microwave that the door is opened or closed. If they play up they could be causing your microwave to act strangely.
Mar 25, 2009 | GE Microwave Ovens
Microwave runs but does not heat
could be door switches could be pcb could be mag, cap or hv transformer.. Its really just a guessing game but one of the above is defo the cause best to get a tech in to have a look or get it replaced whichevers best for yourself
Nov 02, 2008 | GE JVM1650 1000 Watts Microwave Oven
Ge over the range microwave
well randy you might want to check the diode and cap with a meter first before getting the mag tube. if both of those parts are fine. replace the tube.
Apr 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
221 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
