Question about DKNY NY5045 Watch for Men
Need screw for watch Style#NY-4285
Customer has DKNY watch Style #NY-4285. Needs the screw that attaches the watch band to the lug of watch. Ladies yellow/brown watch.
  • jandwdoc Jun 16, 2009
    Would like you to supply us a part for the customer.
  • 58 Answers
Hi, you should be able to get one from a watchmaker
Posted on Jun 22, 2009
I am looking for a replacement glass for my DKNY watch, model no: 250109
please see attached website.www.esslinger.com/watch-crystals/
Jul 16, 2016 | DKNY Watches
I have a DKNY NY-1251 but i need the instruction to work it because it not working with new batteries. it was working but keeps on stopping
If it is an analog watch and the second hand moves a few time then stops and sort of twitches then the watch battery (even though new) may be bad. If not the the watch is dead and needs repair.
Jul 04, 2016 | DKNY Watches
What is the wideness of the strap? I want to change it, and I don't know which strap's size should I buy.
At the point where the strap attaches to the watch - take a ruler (with metric on it) and measure the mili-meters (MM's) between the LUGS (points of attachment). That will give you the size of your band.
Dec 09, 2014 | Casio American Apparel Womens Silver...
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
I have a dkny watch that i need to adjust the band on...it does have arrows and what appears to be small screws.....
it doesn't have arrows because you have to use small screw drivers to loosen it. so you can adjust it. You can buy it on any hardware store. i hope i had been helped you.
Jul 24, 2011 | DKNY 1035 Wrist Watch
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    Resize DKNY 1035 Wrist Watch band
    Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
    Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
    Jan 10, 2010 | Watches
    Watch bands f/ Kenneth Cole
    Replacement watch band (f) can be purchased from amazon, take a look here: Amazon com kenneth cole band Watches Women Clothing Shoes Jewelry Wish you best of luck. Cheers
    Jun 22, 2008 | Watches
    Dkny watch- repair, need extra links
    I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
    Mar 09, 2008 | Watches
    DKNY NY5045 Watch for Men Logo
    661 people viewed this question
    Top DKNY Watches Experts
    Ansel Alberto
    Ansel Alberto
    richie46
    Are you a DKNY Watch Expert? Answer questions, earn points and help others
