Question about LG VOYAGER VX10000 Cellular Phone
My touch screen is broken
When i touch the screen it is completely inaccurate and it cannot be calibrated
    Problem Solver:
  • 9 Answers
Reset the phone to factory settings and then calibrate it
Posted on Jul 18, 2009
Calibration for 8060 touch panel
Press and hold down energy saver button and function button together then power on the machine. keep on holding the two buttons the machine will once show screen calibration marker then again show the calibration markers now touch the shown marker it will go to a new place keep on touching the final marker will be at center of screen . after touching it the calibration completes
May 05, 2011 | Panasonic Workio DP-3530 Copier
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Jun 17, 2009 | Sony Ericsson P990i Cellular Phone
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Nintendo ds
when u go to settings in the main thing when u turn it on you have to hit the buttons percisely like bulls eye on the dot or nothing will happen.there is another chance that your touch screen may be broken from taping it to hard or doing somthing to it so it may be harder to tap it but if ur screen is broken well.........then if it goes completely out like when u touch it then its broken for sure but that may solve ur problem
Oct 26, 2008 | Nintendo DS Lite Console
UNABLE TO CALIBRATE TOUCH SCREEN
The only possible fix is to try to clean the edges of the screen in case any particles are trapped between the screen and the case, this can confuse the touch screen.
Do this with a soft toothbrush, it will not damage the screen.
If that doesnt work then in all likelihood the screen is broken, it can be replaced but this is not trivial. There are guides on the internet on how do do this.
Dec 30, 2007 | Nintendo DS Console
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
LG VOYAGER VX10000 Cellular Phone Logo
285 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
