Question about ASUS A7V8X Motherboard
Asus a7V8X- X stucks in the main screen of ASUS that's all
THis board starts reads everything but don't boot and nor open  the windows screen, gets stuck in the main opening of the board,no speakers signal to tell me anything.STucks in the mais initial screen, and power light is on , any ideas thanks,
Just get a new mother board
Posted on Nov 15, 2007
    Problem Solver:
  • 14 Answers
Does it come up with any warning messages in POST? if not try removing all unnecessary components, eg all cards except for video, use only one stick of ram in the last DIMM slot and all usb cables from the back except for keyboard and mouse(if usb). Boot it up then if it goes right through switch off and add a component then try again, use this process until it stops responding, then repost what caused it to stop. Otherwise if removing all those components didn't make it respond properly try updating your bios, on your motherboard it has the Asus EZ flash utility so you can do this straight from the bios screen, all the instructions and software you need can be found here
instruction links on the left, downloads on the right just make the appropriate selections from the drop-down menus.
hope this helps.
Posted on Nov 01, 2007
You can download the required manual by clicking this link:
Alternate link:
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
Hope this solves your problem. Thanks for using FixYa
Jan 13, 2010 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Did I fry my ASUS A7V8X-MX motherboard? I bought an old computer(with this moboard) that was working. I opened it and put in my old HD to slave it. Rebooted to get into the BIOS (just to check things...
I do not think that this problem is to do with your Motherboard. If you had fried your Motherboard, you would not see anything when you started the computer, you especially wouldn't be able to get in to the BIOS if your Motherboard was damaged because the BIOS is accessed straight off the Motherboard itself. You will notice that if you take out all the Hard Disks in your computer, you will still be able to access the BIOS.
This problem is probably due to a corrupt Hard Disk. Maybe you set the old Hard Disk to the Master or whilst moving your computer you damaged the other Hard Disk. This problem is known as the Windows Reset Loop, your computer will not get past a certain point in the start-up process and will then restart itself and do the same thing over and over again.
This could also be caused by a problem in your BIOS, when you did the CMOS reset, it would have probably knocked out all of the stored data. When your computer is starting up, you must go in to the BIOS and check which drive the bios is set to boot off. Even though your Slave Hard Disk is set as a Slave, you can still set the computer to boot off this drive, and if this drive is corrupted it will not boot, it will go in to the Windows Reset Loop.
If the problem still persists, i recommend that you remove the old Hard Disk which you have put in and try and boot off the Master as a single drive. If this still doesn't work, set your other Hard Disk as the Master and remove the other drive and try boot off that one.
If you would like further assistance with this problem, pleas do not hesitate to contact me on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
Jan 01, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
Asus driver?
here is the link to the page that will get you going
Sep 18, 2009 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
"stand by" option not active
It is configuring in "power options" in control panel
Aug 11, 2009 | ASUS A7V8X-MX SE Motherboard
BIOS issue or ? Rebooting PC into BIOS on ASUS A7V8X-X ACPI BIOS Revision 1003, 13.2.2003
If you lose time and day, means the little battery on your motherboard is done. Get a new one, replace it, should be fine then. As far as booting into BIOS, there should be a boot option, and you can boot into a hard disk, a usb or a cd rom drive. Of course in this case, choose the hard disk that has your operation system on it.
May 30, 2009 | ASUS Computers & Internet
Reading error
What type of HDD is this? IDE; SATA; or SATA II? The problem probably is that you are trying to use a SATA drive with a SATA II board. They are not backwards compatible. Hope this helps.
Dec 17, 2008 | ASUS A7V8X Motherboard
Sata unable to recognize my book 500gb
The A7V8X-LA motherboard only supports SATA1. Your new hard drive is likely SATA2 (SATA-II). You'll likely need to change jumpers on the drive to make it compatible with SATA1.
It's a tiny bit slower than SATA2 (okay, twice as slow). But, it's still faster than PATA (IDE).
David L. Burkhart
Burkhart Technology Services
Jun 22, 2008 | ASUS A7V8X Motherboard
Presario SR1030NX - with a ASUS A7V8X-LA motherboard, won't boot.
those are notoriously bad boards. i have worked on 2 or 3 of those boards and founds its adefect on some voltage regulator on motherboard..
best thing u can do is upgrade motherboard and cpu and ram in a combo.. don't forget power supply unit, new stuff needs at least 350watts
Nov 06, 2007 | ASUS A7V8X Motherboard
ASUS A7V8X Motherboard Logo
136 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
