Question about Unotron S5100KG Keyboard
We have tried to boot our computer this morning and we received a black screen w ctl+alt+del with NTRL. After I went into setup I saw a keyboard error. How do I fix?
    Problem Solver:
  • 19 Answers
Try using a different keyboard if you have one around, you can pick one up at the store fairly cheap if you need a new one, otherwise to see if it is the computer, try another keyboard from a different computer. If that doesn't work try a usb keyboard when you can get one.
Posted on Nov 16, 2009
Have a hp pavilion a705w that shut down one day and upon restart NTLDR is missing error came up and said hit alt clt del what do i do
Windows was writing to a file when the power went off. Now windows files are damaged. I'm assuming you have Windows XP on the machine. Do you have your Windows XP cd?
Mar 16, 2013 | HP Pavilion a705w PC Desktop
What keys change bios values on asus u46e
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
What keys do I press to get the CMOS setup screen on a Compaq Presario 5222?
Try F2 or F8 or F9. Shouls tell you just before the splash screen comes up ...
Jan 28, 2012 | Compaq Presario 5222 PC Desktop
My Gateway zx4800 booted this morning to a black screen with one window stating, "Personalizing Windows Media Player". It stayed that way for an hour. Ctl Alt Del finally let me select Task...
Good Day,
As I see it, the OS which is Windows 7 has automatic updates turned on, thus Windows Media Player has also been updated. If you have quitted or stopped the installation or "personalizing Windows" it may have this effect of slowing your system down.
To fix this you may restore the system at least a day before it bogged down.(boot into safe mode first) after which see the results, and let it re-update, and let it finish shall it show that screen again. Depending on your system configuration, Windows Media Player setup may take a while.Just be patient.
Hope this helps. Thank you for using Fixya.
Jul 10, 2011 | Computers & Internet
How do I get my computer restarted from a black screen when ctrl+alt+del does not work
Hold down the Ctl + Alt+Del keys together for about 15 seconds, this should put the system into a state that allows you to disconnect the power for about 3 minutes.
Plug the power back in and re-boot in "Safe Mode", this will flag up any errors and more than likely repair the system files as it starts up.
If still nothing listen for error codes when it is powered up, this will give a rough indication as to what is faulty, VGA, RAM, Sound card etc.
Was anything being changed or unplugged/plugged in just before it went wrong?
Hope this helps.
Nov 03, 2010 | Computers & Internet
Getting message bootmgr missing press ctl alt del, but when i do this nothing happens
try this.. reboot your computer, or hold down the power button to shut it off then turn it back on, at the acer splash screen hit f2 to enter into setup. hit f9, load setup defaults and exit. it will reboot your computer and should let you in.
Oct 10, 2010 | Acer Aspire 5536-5224 Notebook
When I turn on the computer I only get a black screen with the message "BOOTMGR missing Press CTL ALT DEL" of course when you press CTL ALT DEL it just brings you back to the black screen with the same...
1. Put the Windows installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
Oct 17, 2009 | Lenovo 3000 G530 Notebook
NTRL is compressed Press Ctrl+Alt+Del to restart
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Please rate this fixya
Jan 26, 2009 | Gateway GT5220 PC Desktop
Which key to enter to bios to format pc IBM pentium III
del.. button on your keyboard old models may require F6
Nov 19, 2008 | IBM ThinkPad T23 Notebook
Keyboard problem
Does the ctl alt del work if you try then during the early part of the start up process, before Windows loads? If they do then I would suspect a problem with Windows as a result of your previous infection OR perhaps you are still infected with something. You can easily eliminate most infections by running complete hard drive scans using virus, spyware and root-kit scanners. I would suggest trying AVG?s free versions of each which can be downloaded here: http://free.grisoft.com/freeweb.php/doc/2/. If the ctl alt del key sequence does not work during the boot process you may just have a keyboard that is going bad. Of the 20 plus laptop keyboards that have I have replaced over the years only two were due to physical damage. The rest just developed bad keys, usually clustered together and usually getting worse over time. Here is a link to a keyboard tester program. This should confirm if the keys are bad: http://www.softplatz.com/Soft/Utilities/Other/Keyboard-Tester.html Let us know if you have any other questions and don?t forget to rate this post.
Apr 07, 2007 | Acer TravelMate 662LCi Notebook
Computers & Internet Logo
128 people viewed this question
Top Unotron Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Unotron Computer and Internet Expert? Answer questions, earn points and help others
