Question about ASUS P5LD2-VM Motherboard
Chassis intruded fatal error - can't access bios
Hi, on installing a new pci soundcard on my friends Advent desktop, powerup fails with a 'chassis intruded - fatal error' message. The system goes through POST, validates ram, checks (and recognises) drives etc then hangs completely.  I've checked the jumper on the chassis intrusion pins and that's fine.  I've also reset the CMOS as per the manual (at least the manual for P5LD2-VM (the board actually says P5LD2 TVM SE/L but I can't find a manual for that model -as far as I can see, the layout is essentially the same).  However, none of this has any effect - the error keeps coming up and won't let me get into the BIOS (or anywhere else).  My friend got the machine second-hand (it was working), and has no mobo recovery disks or anything.  I've scoured the net for a solution, but so far, nothing I try solves the problem.  The board is running a Intel Core 2 1.GHz CPU by the way.
I'm not an expert, by  a long way, but have built a few machines, and tinkered with others and this is the first time I've hit such a seemingly impossible problem (and it had to be on someone else's machine!) Any suggestions will be gratefully received before my friend becomes my ex-friend!!
  • 3 more comments
  • shanakie Nov 01, 2007
    thanks Wraithbearer - I had tried rebooting with the card removed, checked all board connections etc but still the same problem. I think I have no choice but to update the bios - as I said my board says P5LD2-TVM-SE/L, but I'm assuming/hoping that the VM-SE bios will be the correct one. I think I should be able to do it via the ASUS EZ Flash utility - I certainly hope so as all other alternatives assume being able to access DOS or Windows which, obviously, I can't do...
    ... an hour later. Having discovered that the board doesn't have a connector for a floppy drive (thus making flashing the bios impossible), on a hunch I took another look at the pins. There are three sets of pins, tho only two were originally jumpered - the top set being chassis intrusion, then cmos reset, then a set with a double gap between pins 1 and 2, like . . . that don't appear in any of the manuals for the P5 series - on the basis that there wasn't a lot to lose by this point, I found a spare jumper and closed pins 2 and 3, booted up and .... after a brief complaint about cmos settings, I was in!! I really haven't the faintest idea why this worked - those pins definitely weren't originally jumpered, and the chassis intrusion complaints began before any pins had even been looked at...
    Whatever, I'm deeply relieved - I could have just bought another board, but the humiliation......!! Thanks for your suggestions wraithbearer - they were well to the point. I only found this board in a desperate search for some ideas, but will stick around...
    regards
    shanakie
  • Anonymous Dec 08, 2007
    Hi guys i do have exactly the same problem with same board ... tried anything ... no solution ...
  • Anonymous Dec 19, 2007
    same prbblem i m also faccing
    saj
  • Anonymous Mar 09, 2009
    "chassis intruded fatal error - can't access bios"
I forget my supervisor password
Posted on Jun 16, 2010
I recently solved this problem by hooking up a case open switch to the mb and holding it while the pc boots up no problem still wanna see where i can turn it off tho :S
Posted on Feb 11, 2009
    Problem Solver:
  • 14 Answers
Hi Shanakie, did you remove the soundcard to see if it worked again without it? If not try that, if it works without it go into the bios and turn of the chasis intruded warning reboot and replace the card, if it still has trouble try it in different slots, if it hangs only in a certain slot try another PCI device in that slot eg. modem, and see if it hangs if it does its a faulty PCI slot or a cap or something to do with that particular slot has gone, if it hangs on every PCI slot and other cards work in any of them it's the card, the card may not be faulty though it may just be conflicting with something on the board you may have to mix and match cards till you find a working configuration. Failing that try updating the Bios this often fixes problems with no other solution, Goto this link
http://support.asus.com/download/download.aspx?SLanguage=en-us
All the information you need to update the bios is on the left hand side, and from the drop down menus on the right select the socket775 series and you'll find all the software that would've been on the motherboard cd as well as the bios updates for your P5LD2 VM SE
Posted on Nov 01, 2007
  • Josh Turner Nov 01, 2007
    Keep me posted by the way, i'm interested in hearing your progress
  • Josh Turner Nov 02, 2007
    Thats crazy i hunted everywhere for your exact board, couldn't find it so i just assumed it must've been a factory typo, but not i'm curious to track it down and check those jumpers, I'll keep you posted, if i find anything i'll post it on here for future reference, because i'd like to know what those jumpers were, perhaps bus speed?
Hello guys...can anyone here give me a license key for nod32 anti virus. i have already software from black xp the problem is that they are asking for the serial key.
Posted on Jun 05, 2009
New CPU installed!Please enter setup to cnfigure your system Chassis intruded! Fatal Error...sytem halted
buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx http://www.helpnow.pk/
Sep 20, 2013 | ASUS P5B-E Motherboard
Chassis intruder,fatal error system halt on asus p5pe-vm.how can i fix it
Hello, you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Please select your windows version.
Select manual and click on global for download.
Unzip the file before installation.
And remove the cable on the mainboard for the contact on the chassis.
When that is done enter the bios and set the setting for the chassis intruder to off
Read about that in the manual.
The chassis intruder is used by admins to see if the case have been opened
when the case is opened the bios will block the system from booting until the setting in the bios
is set back to normal.
Oct 06, 2011 | ASUS P5PE-VM Motherboard
(1)cpu fan error (2)chassis intruded (3)fatal error.....system halted
The reason for this error is Overheat! Please replace the CPU Fan with a new one and add additional Fan for the CPU Cabinet in order to cool the CPU. Then, reset the BIOS to default value by pressing the F2 Key or Delete Key at the Startup and select Load Optmized Defaults or Load Fail Safe Defaults option. This should resolve the issue.
Mar 02, 2011 | Computers & Internet
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Jul 21, 2010 | ASUS P5KPL-AM SE Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Hello, I recently bought this motherboard and I have installed and inserted all the required wires. When I started the desktop up it came up with the error "Chassis Intruded, fatal error... system...
well mate you have just broken the seciurity seal on your PC and now you need to contact PC manufacturer for assistance because they only would know how to reset this message.
Jul 18, 2009 | ASUS P5SD2-X Motherboard
Chassis intruded
Can you access the bios? You should disable Chassis intrusion, I don't really see anyone needing it if it's just a home pc.
Jul 08, 2009 | ASUS P4P800-E DELUXE ULTRA ATA133...
ASUS P5LD2-VM Motherboard Logo
7,962 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
