Question about Canon Office Equipment & Supplies
Cannot enter service mode to reset e007. - Canon Office Equipment & Supplies
  • Bob Brenton Jun 17, 2009
    Hi sunilratlam,
    thanks for the info. Just got back from the call. Here is what I tried.
    I went in and disconected all connectors on all boards. When I repowered the machine I immediately pressed * 2&8* and i saw the service mode first page display then machine went right back into 007-01 code. I then shut off machine and tried again but dont get to the service page it immediately goes int code. Long story short it looks like the buttons are not sticking. I think (and not being a Canon expert I dont know) as if I have a board problem. Issue is which board would lock up machine.
    Sergeant:
  • 199 Answers
For IR model press star * then press 2 & 8 keys at the same time and then press * again,
(if there are star (*), 2 or 8 key are not working, it's not possible to get enter in the setup mode.
for NP model there are a small push button inside the front door (press only from a thin pin because there are a very small hole to push them) to enter in the setup mode
Posted on Jun 17, 2009
  • Sunil Rathod Jun 18, 2009
    what's your copier model
    E007 0000 An error in the rotation of the fixing film is detected.
    The reading of the main thermistor is 100°C or higher and, in addition, the
    fixing film sensor does not detect the rotation of the film for 6 sec or more
    while the fixing motor is driven.
    Main cause The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
    Caution To clear the error, execute the following in service mode:
    COPIER>FUNCTION>CLEAR>ERR.
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
I am trying to enter into service mode in ir 2016 copiers but it is not showing anything....
Hello, you do not need to enter service mode to reset E007.
This error tells you that there is a problem with the fixing assembly.
You can solve this by replacing the fixing unit or replacing the fixing film with a non OEM one.
In any case, if you are a stranger with repairing copiers you better call a tech.
The cost for repairing is about 200-300 $.
Dec 31, 2014 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
How to reset IR2020I
May 09, 2014 | Canon iR 2020i Laser Printer
My canon IR 2018 copier is giving me system error E007
This is a problem with the fuser unit, this is the section that heats up. Once the code comes up you will need a service tech to come out to check your copier. The code can only be reset by entering the service mode. If your lucky and all looks well in there it may just need to be reset with no parts to be replaced.
May 17, 2010 | Canon iR 2016i Black and White Copier
For 3 days now, my canon iR2018 has been showing a warning light that says system error and the error number on it is E007.
Hello sir; Sorry for delay, E007 is a fuser problem, it can be reset ;
press "additional function" "2" and "8" keys in that order, SSSW will display, press "OK" enter 1 using up/down arrow key,then enter bit switch 1 by using left/right arrow key, then change value from 0 to 1 or from 1 to 0,press "OK", press "stop", to end the service.
Nov 09, 2009 | Canon Office Equipment & Supplies
Canon printer IR2016J show error code E007. Please advised me on how to resolve it or rese it. Thanks
i have a canon copier IR2016J shows me error code E007 please advise me on how to resolve it or rese it. thanks
Jul 01, 2008 | Office Equipment & Supplies
291 people viewed this question
old marine
old marine
