Question about Lexmark Z615 InkJet Printer
Text hard to read very faded.think its dust how do i clean it
    President:
  • 1,185 Answers
Dust does not cause fading on printouts
Poor Ink supply or dirty head does
Check in your screen software for the head cleaning program and use it
Are you using Lexmark cartridges or copies, if you are using copies the software cannot see them and does not report a low level
If you are using genuine or really good copies then you may need to use a head cleaning cartridge
try www.choicestationary.co.uk for infrormation on the above
Posted on Jun 16, 2009
Samsung CLX-3160FN problem with faded black images/text only
Many of today's printers have a "toner save" option, which makes the black appear lighter, and I'm pretty sure this isn't your problem. However, I wanted to rule-out the obvious first, which is just a setting.
If you're seeing the black lighter in vertical "stripes" or segments in your printing, then it's most likely due to a dirty toner cartridge (but you said you replaced it), or cleaning the LSU inside the unit (as it says in the owners manual).
Just in case you don't have the manual handy, here's an online link to it:http://downloadcenter.samsung.com/content/UM/200611/20061122152910875_CLX-3160_English.pdf
I hope this helps!
Feb 13, 2012 | Samsung CLX 3160fn All-In-One Printer
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
I have a problem with the colour prints...there are different kind of lines all over the page..how can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Images fading fast. Cannot read text on screen. Could hardly focus on images. Need to obtain part: Screen Focus Block
The lens is getting clogged. All u need if u have little expertise open up the TV.
and clear the lens or projection hd there with a soft clean cotton cloth
May 29, 2009 | Hitachi 51F59 51" HDTV Projection...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Letters are fading hard to read
Buy a new keyboard. they are real cheap on line, try Newegg.com
You should find one for around $10 USD. Or, you can try cleaning the keys on the keyboard with rubbing alcohol.
Dec 22, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Black ink.
Bought a remanufactured cartridge on ebay,it is faulty.I refilled the old one & have no problems now.dave
Jun 30, 2008 | Lexmark Z615 InkJet Printer
My printer is printing fine with all the colors but the black is super faded
get in touch with your Samsung dealer or Samsung direct it speak to the IT departement if the printer has only printed 5000 or less pages total then you could get it repaired on the warrenty the main problem that is causing this is the optical print unit is damage or faulty- mainly the latter...
Apr 24, 2008 | Samsung CLP 300 Laser Printer
Lexmark Z615 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
