Question about Briggs & Stratton Garden
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the wand the washer stalls. Can you advise as to what the problem is and how to solve? Thanks ****
    President:
  • 1,111 Answers
The pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Posted on Jun 20, 2009
WHAT KIND THE SPARK PLUG I NEED TO REPLACEMENT TO MY QUANTUM 6.5 H.P MODEL 020207.,2400 PSI, GPM 20,
Posted on Apr 23, 2014
  • Haley Dobbins
    Haley Dobbins Aug 16, 2014
    its electric. boogie woogie woogie
I have a Xtreme Kleen electric pressure washer that will not turn on. First there was a humming then nothing. Check for current all is good.
Posted on May 28, 2010
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
How do I reset the mixture screw on my Honda GC series 1800psi 4.0 HP premium residential pressure washer?
use a starting setting of all the way in then back out 1 1/2 to 2 turns adjust for best run after that
Jul 15, 2015 | Honda Garden
Briggs stratton quantum xte 55 manual
PartsTree .com or PartsTreeRepairClinic
Jun 23, 2014 | Briggs & Stratton Garden
Rac pressure washer leaking water through manifold
Yeah, that is never good. I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Apr 21, 2014 | McCulloch Electric Pressure Washer 1800psi...
Quantum xte power washer
carby full of oil due to possible roll over of machine, remove carby bowl and clean with brake cleaner or similar. re assemble and try, disconect oil pressure switch while testing to eliminate that issue, usually connected to off switch.
Apr 02, 2014 | Briggs & Stratton Garden
I have a craftsman 6hp quantum xte pressure washer and while it is running there is oil spraying out of motor.
This depends heavily on where the oil is coming out of the engine. A very common issue is to have at some point tipped the machine over. This causes the fuel to run through the carb and down into the crank case. When this happens you will end up with the crank case being over filled with the oil / fuel mixture and will see things like what you are describing.
Check your oil and see if it smells like gas. If it does drain the oil and replace it with 30WT motor oil. You will likely need to replace the air filter and spark plug as well as it is common for the filter to become oil soaked and the plug to be fouled when this occurs. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, Inc.www.landanw.comaron.kerr@landanw.com800.247.8103
Apr 13, 2012 | Briggs & Stratton Garden
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Looking for manual fh160d pressure washer Mculloch
Have you tried their website for the manual. Most products have websites with the manuals their for those that loose them or whatever reason they need another one. they are almost always free to download and print too.
Jul 13, 2010 | McCulloch Electric Pressure Washer 1800psi...
Need owners manual
hi, have a look on this site...it has just about every owners manual
http://manuals.syntigroep.nl/manuals.htm
Jul 23, 2009 | Garden
Garden Logo
2,044 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
