Question about Estate TEDS740JQ Electric Dryer
We have tried 3 maytag and now one whirlpool electric dryers at our lake house...all new but they all take toooo long to dry what I think is a very reasonable load. We checked the outlet for power seems fine ..the dryers warm up but just take too long.. The vent seems fine. Could it be the power cord they have connected it with?
  • 72 Answers
The problem is not the power cord, it maybe the length of the venting. Every elbow is equivalent to 8 more feet of pipe. Not sure which model you have. How long is the length of vent? Does it go right out the wall?
Posted on Jun 16, 2009
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
Thesawdustmaker@msn.com
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Aug 05, 2008 | Whirlpool LER5636P Electric Dryer
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dyer works, heats up but the door keeps popping out and stop
REPL/ THERMAL FUSE LOCATED IN REAR (IF) LINT SCREEN ON TOP// OR LINT SCREEN INSIDE DRYER REMOVE METAL HOUSING WERE LINT SCREEN GOES INTO AND BEHIND THAT IS THERAML FUSE WHITE IN COLOR 2 RED WIRES CONNECT TOOOO......
Nov 29, 2008 | Whirlpool LEN2000PW Dryer
Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
70 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
