Question about Jensen VM9510 Car DVD Player
Cant play dvd because of parking brake switch.
  • 4 Answers
There is a way without having to have a ground switch but you MUST have your remote present.
Posted on Jun 18, 2009
Cant play dvd says parking brake on screen
you can not play dvd's when the car is not in park with the e brake on. I"m assuming it was factory installed or by a dealership??? they hook a line from it to your brake sensor. it's illegal to watch movies while you're driving. so long as theyre behind your seat and out of your view theyre legal, otherwise they hook it to your brakes.
Aug 14, 2012 | JVC Kwav60bt 6.1" Dvd Cd Mp3 Double Din...
Cant play dvd when driving on my jenson VM9312
That is due to the parking brake sensor on most DVD players. Since it is higly illegal to play DVDs while driving, as it provides a distraction to the driver, it is frowned upon. However, you can simply ground the parking brake sensor wire, and that should fix the issue of it not playing when driving. Please remember that it is most likely illegal, though.
Oct 26, 2009 | Car Audio & Video
My lanzar sd31mu says that i cant play a DVD while i drive I want to know what to do. Thank you.!
there is a wire that goes to the parking break warning light switch, simply disconnect to watch while you drive, but this may be illegal so I would say don't do it, not to mention dangerous.
Oct 10, 2009 | Lanzar SDBT75N Car DVD Player
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
Installed a dvd player but i can't get it to play dvds
On the parking brake under the dash is a switch at the top that actuates the parking brake light. On most vehicles most are two wire switches, but some are one wire switches. If you have a two wire switch then you can unplug it and use a test light with the ignition turned on without starting the vehicle and test the wires to see which is the hot wire and then connect to the one that has no voltage on it because it is the ground for the switch. The wire is used to detect the parking brake position as engaged before it will allow viewing of the DVD player when the vehicle is not moving. When the brake is off the DVD player will not play DVDs, this is a safety measure so the driver will not be distracted while driving. Good Luck, RAC
Apr 20, 2009 | 2003 Chevrolet Trailblazer Ext
How do i bypass the parking brake switch in order for my video to play
run a jumper to GROUND from that lead. it must remain shorted all the time you intend on watching the dvd player. With that said, I have one in my car that is hooked up that way and I put mine on a toggle switch so that, in the event I get pulled over I can hit the switch and it won't work unless I pull the brake. If you get caught wacthing a movie while moving, there is a fine associated with it! just letting you know. but its very kool to have it on long trips.
Mar 03, 2009 | Kenwood KVT-512 Car DVD Player
Dvd wont play
If you hooked the parking brake wire up, sometimes those units require a double pulse. meaning that you set the brake for 1 sec., release for 1 sec, then reapply. then there will prob be a 3 to 5 sec delay before you get video. try that and see if it works. If not get a toggle switch from a local auto store and hook the parking brake to one pin and ground the other. Then treat it as the parking break.
Dec 09, 2008 | Car Audio & Video
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
Jensen VM9510 Car DVD Player Logo
107 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
