Question about Sharp R-630D Microwave Oven
Display and heating problems
1)-The small alphanumerical dots that make up the LCD display are starting to drop out (not seen) making interpretating the display difficult when running or inactive.
2)-Another recently surfaced problem is that the the unit will cut-out heating while the carousel still turns and countdown timer continues until the end of the requested cooking time.
Regarding #1, the display problem, I tried unplugging the unit from the power source, waiting at least a minute, then re-connecting the power cord. This action does nothing to help the display, although...once in a while...the display will suddenly work as it did when first purchased. This state usually lasts all but a day at the most before reverting back to the described problem state as mentioned in #1 above. I even tried to use my fingers to lightly run across the membrane type keypad to feel anything 'odd' where the contacts are located underneath. I felt nothing unusual.
Regarding #2, the power cutting out, I tried connecting/re-connecting the unit from the power source with no success. The unit does heat the contents and the carousel does turn, but the power intermittedly stops premature during a heating session. This is a noggin scratcher for me.
Hope there is something I can do to resolve this sate of my unit. Thank you in advance for your answer(s)!
EZ of NJ
  • Anonymous Mar 05, 2008
    I have had the same problem with mine for a couple years now evidently the displays must have a weakness in manufacturing
  • Sharp Master
  • 9,098 Answers
Problem #2 is a bad door switch or door switch mount.
Problem #1 is a trouble with the control unit / display.
The avergae do-it-yourselfer can replace a door switch if he follows the proper safety and repair advice.
We repair control units on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya:
When you get to our site, do a Ctrl-F search for R630.
We also have the entrie service manual for these on our site.
Posted on Nov 05, 2007
  • William Miller
    William Miller Nov 05, 2007
    Hey Guest,
    F3 (depending on brand and model) is usually a defective thermistor or temperature sensor, vbut on GE's it's a bad keypad.
    I'd put my money on the peypad in this case.
    If you have a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here:
How do I set the clock on my sanyo microwave
Usually, if there is a Time/Clock button on the panel, pushing it once blanks the display for timer input while pushing it twice makes the colon blink (the two dots) meaning it's expecting the time input. So, for 12:37 you would push Time-Time-1-2-3-7-Time.
Apr 26, 2015 | Sanyo Microwave Ovens
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see
May 31, 2012 | Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
I have a sharp 1900 w/r 24 at microwave, display shows a single green dot, when switched on at the wall I just hear a normal sound as if the unit is operating but nothing works
In this case as the display does not show a clock then it seems the program controller is not working correctly. So check power - step down supply, if the pads are responding- if not faulty pads. Also the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
Now identify the parts by clicking this link:
Now unless the display works and the processor starts to switch on the MAGNETRON , the table and light will also switch on as it must heat.
So it is necessary to check the main controller unit as it seems to be the suspect..
Aug 23, 2011 | Sharp Microwave Ovens
The lcd display is not displaying properly at all and the light is no longer working. But its still heating! Could it be some sort of fuse?
It will be the display driver or illumination that has packed up. A replacement display panel is required.
Consult an authorised Microwave dealer for price and advice.
Dec 23, 2010 | Microwave Ovens
Hums, does not heat when started. Display, timer,
The problem could be the high voltage fuse or the magnatron assembly. replace both to be safe. good luck.
Nov 12, 2009 | Sharp R-1610 Microwave Oven
Sharp R953M combination microwave oven
No this lcd card is only a diffuser to even the light out over the display . The part you require is SH3816 Pcb display available from CIS £68.43.
Jun 16, 2008 | Microwave Ovens
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
I wiggled the ribbon cable between the control board and the intermediate circut board. The LCD came back for an instant. I am sure it is this ribbon cable. It looks like it is held on with adhesive. How can it be impossible to repair if people are offering to do it less than 40.00 dollars to fix it? Someone must be selling a replacement ribbon cable that will work.
Mar 20, 2006 | Sharp R-1501 Microwave Oven
Sharp R-630D Microwave Oven Logo
100 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
