Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
AFTER THE LAMP BLEW OUT I REPLACED IT BUT NOW THERE ARE SMALL BLOTCHES ALL OVER THE SCREEN BUT MORE APPARENT WHEN BACKGROUD IS LIGHT, ALSO BULB SEEMS TO BE AT HALF POWER YOU CAN BARELY SEE THE PICTURE UNLESS YOU TURN LIGHTS OUT. MY WEGA IS A 42 INCH AND 5 YEARS OLD. SOMEONE SAID I NEED NEW LAMP ASSEMBLY. ANY IDEA'S ON WHERE TO GET ONE?
I have the same problem. I thought it was my bulb as well. I changed it out today and same problem persisted. I called Sony today and they told me about a class action case on this issue, but it ended in 08. I was told to contact an auth. dealer and call back with the breakdown of the problem. They said then I will be presented with some options? doesn't really sound good to me.
Posted on Jun 18, 2009
    Problem Solver:
  • 10 Answers
Frys electronics
Posted on Jun 16, 2009
Orange light came on replaced the bulb after a day it blew out then replaced bulb again blew out now the light is red please help
It sounds like it is not getting enough cooling. Clean the cooling paths. I am just taking a guess as I am not familiar with this unit.
Jun 16, 2014 | Toshiba 72HM195 72-Inch Diagonal...
Hc1500 projector will not turn on
Sounds like the lamp. The only way to really check it is to either put a new bulb in or put the old bulb in a different projector. Neither of which probably help you at this point. But, it does sound like the lamp is blown.
Mar 30, 2014 | Mitsubishi HC1500 DLP Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Purple blotches
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Nov 28, 2007 | Epson Livingstation LS57P2 57" Rear...
Replaced bulb & tv not working
did yo here the ballast start up also ,it generates the voltage for the uhf bulb,try to lesten foe a small arcing noise from the rear of unit.also make sune you installed the lamp correctly ,seated there are switches that let the set know when the lamp is out of the set,/
Aug 23, 2007 | Sony Grand WEGA KF-50WE620 Television
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
