Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43UWX10B 43" Power Light flashes Continuously
My Hitachi 43UWX10B 43" Rear Projection power light flashes continuously and you hear the chirping of the TV trying to turn on with each flash. The TV will not turn on. The previous owners were told it was a fuse when they had it repaired professionally with the same problem. After inspection, it is obvious the IC convergence chips have been replaced but I cannot find any fuses that seem to have been replaced or that need to be. After testing the convergence chip's resistors only one was bad, it was out of tolerance, and I have replaced it. Any advice?
Thanks for any help.
  • sum10fishy Jul 08, 2009
    Ed, thank you for the reply. I have now replaced the IC convergence chips and tested the resistors on the board. However, the problem has not changed. What else should I check to contine trouble shooting this set?
  • Hitachi Master
  • 3,459 Answers
I doubt if its the fuse. We just helped a customer with a very similiar problem. Its more likely that the convergence IC have failed and shorted out. When this happens one of the symproms is that the TV will shut down and chirp. Goto www.TvRepairKits.com and click the contact us button. They can provide you with more instructions on how to test if this is the problem.
Ed
Posted on Jun 20, 2009
Hitachi 43UWX10B - LED Light on constantly on will not go off
Power relay is defective. All contacts are not opening when power is removed. Located on small power supply board, upper rt side.
s 901 part# FJ00142 should be under $10, do a google search with part number and 50 sources will appear.
easyab
s901, FJ00142
Jul 14, 2010 | Hitachi 43UWX10B 43" Rear Projection...
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have a Hitachi 43UWX10B that won't turn on. When I try, the red power light flashes, and I hear intermittent chirping. Any way to verify the problem and estimate repair costs?
Your convergence chips have failed.
Sometimes when they fail the TV will look 3D or distorted and sometimes it will just loose video and audio and chirp.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Power light turns on turns off continuously
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Jul 31, 2008 | Hitachi 43UWX10B 43" Rear Projection...
My 43uwx10b is havin problems power light flash
check relay s901, FJ00142 you may have to solder out part and solder in new parts.
Dec 31, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10b tv ceeps bepping or cherping
Research at www.HitachiServiceUSA.com....................T.
Nov 04, 2007 | Hitachi 43UWX10B 43" Rear Projection...
43 inch Hitachi UltraVision model # 43UWX10B
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Flashing Power Light
Located in the power supply section of the unit. There is a pico fuse (soldered in fuse) that opens up and there is no high voltage. The second click that you hear when the set is turned on. This can be diagnosed With set unplugged, with an ohm meter with a simple continuity test. I think the pico fuse is 4 amps , I am not absolutely sure. I have seen this problem in that unit previously. There is also a convergence problem that occurs with that set. Scrivitron.
Jun 16, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
254 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
