Turned off TV, came back a few hours later, turned TVon and nothing happened checked plug to make sure it was in, I was wondering if there is a fuse inside the unit that could blown, before I try to take it apart, the Tv is 15 yrs old this is the first problem, if it is not a fuse, is it worth having fixed
Tries unplug,replug the tv like an hour later,the tv,now will reset itself back to the factory setting,tv should work now.Not,than the power supply board is having problems,not giving wright voltages to the tv anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
well, yew can try and pull out the cord 1st...then, wait at LEAST 12 hours and plug it back in! If it turns on, and cuts off 3 seconds later, try to pull tha cord out AGAIN and plug it BACK IN and it SHOULD work! :D :3 i have had multipe problems with my RCA television set, and this was one of them!!
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v, Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993 [email protected]
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
exact same problem
