The clutch cable came loose from 2bolts that attach it to the top handle control. The cable appears to loose to engage the self propelled drive if I reattach it. Does it have to be replaced or can the tension be readjusted?
SOURCE: Honda Harmony mower starts but will not stay running
rebuild the carberator. easier said then done huh. anyways, thats your only soluation. hope this helped you
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
SOURCE: the self propell quit. looks like the cable is
go to the hardware and they have links you can but to connect both cables back together, or solder it
SOURCE: self propled honda mower
take ut honda mower to the nearest show as its consist of warranty on the products.
if u take it the mechanic or u open personally u can loose ur warranty. and its other benefits
to change the cable you need to take apart the drive something was not installed correctly
