Question about OKI B6300 Laser Printer
Can't put back ink cartridge in machine. wont' go back in
Our ink cartridge that was bought for our OKI B6300 wont go back into the machine. It's a new cartridge and taking it out was easy, now it won't go back into the machine the same way it came out.
  • 518 Answers
USE A BIT OF FORCE, NOT TOO MUCH, BUT YOU WILL FIND IT CLICKS IN
Posted on Jun 16, 2009
Aquired oki b6300. it has old company info and passwords. how to reset for my company?
1. Turn off the printer.
2. Hold down the shift and LF buttons at the same time and turn the printer back on
3. Release the buttons
4. The printer should be reset to factory defaults now
Sep 15, 2013 | OKI B6300 Laser Printer
Trouble with Oki B6300 drum/toner cartridge replacment. Can't get back into the menu to reset the printer.
Try removing and then reinstalling. If this happens since you changed the drum and toner, then the issue would be with the defective replacement. Way to test is to reinsert the old drum and toner and if this does not happen, then you know the issue is with the new supplies
Jun 12, 2012 | OKI B6300 Laser Printer
OKI B6300 Laser Printer stays in a "please wait"
An initialisation fault has occured
There is a component fault with the machine.
The infomation supplied is insufficient to diagnose the fault any further
Feb 14, 2011 | OKI B6300 Laser Printer
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
My printer says set drum/toner cartridge. How?
RESET OKIDATA TONER DRUM
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 28, 2009 | OKI B6200 Laser Printer
OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Feb 12, 2009 | OKI B6300 Laser Printer
How to solve "reboot printer (010-349)error in OKI B6300 printer
This is a fuser disconnection error. Try to remove the fuser and put it back securing properly in its place.
Jan 20, 2009 | OKI B6300n Printer
What does the following error msg mean on a Oki B6300 printer
la verdad nc a lo qt refieres o mejor dicho no t entendi la pregunta......
Jun 13, 2008 | OKI B6300n Printer
OKI B6300 Laser Printer Logo
163 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
