Question about Canon EOS Rebel G 35mm SLR Camera
Flashing battery symbol, not fixed by new batteries
I've had my camera for about 8 years now and have had no complaints. I've had to replace the batteries several times, but recently, when I bought and inserted new batteries, the problem persisted. When I try to shoot, the flash pops open, but that's it... An image of a battery (which looks drained) appears on the screen (this camera is from the pre-digital days), but I can't determine why, as I've already tried changing the batteries. Help!
    Novelist:
  • 155 Answers
Have you tried just the one set of replacement batteries?
Cheap batteries can cause this problem (they are the right voltage but can't supply sufficient current) or sometime you can just get a dud.
Once you have ruled this out, check that all the battery contacts (both on the batteries and in the camera) are clean and free from any oxidization.
Hopefully this will solve your problem. It would be highly coincidental if a fault developed at the same time as the batteries ran out.
Hope this helps.
Posted on Jun 16, 2009
Nikon f80 is dead
Dead circuit - return to seller and get refund
Dec 11, 2012 | Nikon F80 35mm Film Camera
Immediately request battery replacement
Standard AA's also have current capacity limits. When you buy them have to check to make sure its fresh alkaline battery 1.5 v LR6 ?
Jun 25, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
How to fix a Canovision 8 VM-E1 camcorder?
replace the battery by the new one.
Mar 11, 2012 | Video Cameras
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
My Franklin have new batteries, I press the key ON and the screen no showme nothing and nothing is nothing. What happenned? What can I do?
Please check if the batteries are placed in the right order. The +ve symbol on the battery should be placed across the +ve symbol on the battery space of the translator. Likewise the -ve symbol should match with the -ve symbol on the device. Try placing the batteries so that they match with the symbols specified on the translator's battery area and switch on the device.
Nov 02, 2010 | Franklin Office Equipment & Supplies
What to do when the camera wont charge? the lights flash but the camera still wont respond??
Some this is due to the battery complaint that the battery has become bad due to use, this can be fixed by buying a new battery or give the camera for servicing .
Jun 13, 2010 | Samsung NV3 Digital Camera
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Turns itself off every time I try to take a photo
I had a similar problem with my Cyber-shot S600. It just turned off every time I tried to take a photo. I bought a Sony recharger + batteries and it fixed the problem. Camera works fine and I'm impressed with the how long the batteries last between charges.
Jan 04, 2009 | Sony Cybershot S650 Digital Camera
Not sure of exact problem
The charger may not be charging the batteries properly.
The batteries you are buying may not be good.
There may be a fault in the camera where the voltage is not being properly regulated.
Your best solution would be to take the camera to a camera service center to have everything properly tested to resolve the issue.
Jerry G.
May 02, 2008 | Canon EOS Rebel G 35mm SLR Camera
Canon MV550i Mini DV Digital- red flashing symbol
from canon's support page:
This symbol indicates an empty or missing backup battery. The backup battery allows the camcorder to retain date, time and other settings when the main power source is removed.
The flashing symbol is not recorded by the camcorder so you can continue filming without problems.
To stop the flashing symbol remove the old backup battery and replace it with a new one, or recharge the built-in lithium battery if the camcorder has a built-in rechargeable battery.
Note: when the backup battery runs out during filming please do not remove the power supply (battery pack) before the camcorder is powered from a household power source and power adapter, or the user settings and date/time will be reset.
For more detailed information please consult the instruction manual.
Feb 12, 2008 | Canon MV550i Mini DV Digital Camcorder
Canon EOS Rebel G 35mm SLR Camera Logo
175 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
