I need to change the drum unit for Nashuatech photo copier machine
  • hitek78 Jun 16, 2009
    model 2205
    The Model of Nahsuatech photo copier is 2205 and I want to know the consumable count resetting code. after replacing the drum unit
Please provide the model of the machine. Thanks.
Posted on Jun 16, 2009
Cl7000 cyan fades on one side of the print,prined black red etc and good, chand the photo and drum .
try cleaning the laser shield glass for cyan. you said you change photo and drum. Does that mean developer unit for cyan and cyan drum unit.
Sep 30, 2014 | Ricoh Aficio CL7000 Laser Printer
I have a toshiba 166 copier,in my print page i have several vertical ghost black line,every thing i do but that's not removed,i cleaned charger wire,and drum,blade,but i don't whats the problem?
that is caused by a drum or Main Charge Grid ,fuser.. check the fuser unit and verify that there are no visible wear marks on the Teflon roller... if not it would be comming from the drum unit (photo receptor) or Main Charge Grid needs replacing? cleaning
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 03, 2014 | Toshiba Estudio 166 Digital Copier Machine
How do I change the drum to a Canon NP 7130 Black and White copier?
Could be the drum or the fuser causing your problem. To replace drum you need to open the machine by hitting the gray release latch on eft ide of machine to clamshell it open. Inside you will see th toner cartridge/ dv unit on the far right and immediately to the eft of that is the drum unit. You need to release the dv unit by turning a lever before removing the drum unit. Should probably call a tech to do this for you so you dont scratch or damage the drum. Drum life on that model is about 30,000 prints. Whats the meter reading on that copier?
Jul 25, 2012 | Canon NP 7130 Black and White Copier
In Konica Minolta bizhub 362 it says ready to copy but I noticed it says "please change PC drum"
Thecopier has a counter the drum unit. "PC" means photo conductor, I don't remember if the copier will lock up if the drum unit is not replaced? There is a counter that needs to be reset once the drum & new developer is installed.
Jul 19, 2011 | Office Equipment & Supplies
Ricoh copier 4022 sc542 sc548 error codes after changing with photo conductor unit type 1027,
If I'm not mistaken, that type of photoconductor is not compatible with your particular model of machine. The SC542 and SC548 errors are related to the fuser unit. It is not warming up correctly. It could be that it needs replacement thermostats or thermisters. It's possible that the incompatible drum unit has created this problem.
Mar 11, 2011 | Office Equipment & Supplies
It says drum needs replaced what is the drum?
In this machine it is located in the unit where you would replace the toner cartridge. It is the heart, its the imaging film like in a camera, that produces the image onto your paper.But it is a solid photo conductive cylinder in your machine, its in the cartridge that pulls out with your toner cartridge. If its life cycle has expired it needs to be replace.Goto your local office supply store and get another drum unit.
Apr 14, 2010 | Brother DCP-8065DN Black and White Copier
Reset Code for Nashuatech 2205
I'm not sure what do you mean i f you mean how to disable the consumable alarm you can do it by the follow step:
press the yellow [clear mode] key, than press the follow numbers 1-0-7 and than press and hold the red key [cancel\stop] until on the screen do not appear the service mode. When the service mode will appear press [copy sp] on the touch screen, then press [5.mode] on the touch screen and press [next] on the touch screen until you come to [5-507-001] ;[5-507-002];[5-507-003] and follow there you need to change the consumable alarm than you want by putting "0" in place of "1".
Jun 16, 2009 | Office Equipment & Supplies
When printing the printer is leaving smears on the left side of the page and random letters. If I make 20 copies, the first 5 and the last few will have the marks. I already changed the drum and all...
you need check
1) you may make sure the smear occur after the photo drum unit or after fuser unit, you can stop printing when the paper goes around between the drum unit and fuser unit,
2) clean or change fuser leaner if the random smear occur after the fuser unit(not after the drum unit).
3) still check new drum unit there is a cleaner on it, it could be the smear occured if not enough cleaned drum surface
hope you fix it
May 06, 2009 | HP LaserJet 2840 Printer
Fuser problem with Brother MFC 9420CN laser all in one
Unplug the printer and allow it to cool.  Then gently wipe off the surface of the photo-sensitive drum with a cotton swab.  If this doesn't work you may need to replace the drum.
Nov 20, 2008 | Brother MFC-9420CN All-In-One Laser...
Kyocera 1810 drum replacement
First, what kind of technical background do you have? Also when replacing the drum you should replace the drum blade. Most of the drum/blade kits do not come with padding powder anymore so you will need the padding powder also -- if you do not use the padding powder you will get drum blade jitter and trash the brand new drum!!!!
TO replace the drum you will need to remove the toner cart., 1-2 covers, the dev. unit (developer) and then the drum unit. You will then have to take the drum unit apart to remove the old drum and blade. *****NOTE***** DO NOT TOUCH THE DRUM SURFACE OR THE MYLAR (RUBBER PART) OF THE BLADE WITH YOUR SKIN!!!!!! The oil from your skin will damage the drum and could damage the blade, again -- then they would be trashed.
I would spend the money to have a trainer tech. come out and replace/ rebuild your photo conductive unit for you. It would be money well spent.
Oct 29, 2008 | Kyocera KM-1510 Copier
27 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
