Question about Syntax Olevia 226T 26 in. LCD Television
I could not get this TV to get a signal in the cable line.
    Problem Solver:
  • 10 Answers
Set tv to cable not air then you will get pic.
Posted on Jun 16, 2009
  • ep1701 Jun 16, 2009
    set tv to cable not air then you will get pic.
Have colored lines at bottom of tv
Hello!
First: disconnect any signal source from your TV, including cable. Unplug TV off the wall or power strip. Let it sit for a minute or two. Plug power back in. TV might turn on itself, might not. Depends on configuration. Turn it on manually, using set's "power" button. Observe the behavior. Lines? TV need repair! Not an armature job. Lines gone? start to connect signal sources back, starting with cable. Observe the picture. No lines? Proceed to the next source: DVD player, and so on. At some point lines might return. Make note, what source causes the problem. Then, you may know what to do next.
good luck,
Alex.
Jan 10, 2012 | Panasonic TCP46C2 46 in Plasma TV
How do i get stronger signal
If you are referring to a cable signal on your tv set, then there are several ways, but first off, how do you know the signal is weak? Analog cable signals typically run at 30 to 40 percent while HD signals on the same line can be as high as 90%.
If your cable connections are firm and have no fray with good cable runs, and is not longer than needed, I would suggest calling the cable company tech support line for troubleshooting. It could be their error in an outside line.
Mar 23, 2011 | Dynex DX-LCD37 TV
Connected cable box to tv with some audio etc 3 plug thing and no signal
Make sure that the TV inout is worrking by connecting a sourrce like a DVD to the input. If faulty the TV input section must be checked.
Secondly if the TV works the cable line from the provider to the cable box must be accessed by a signal tester. call the service provider to confirm the signal or if there is any break inthe line.
Finally connect the output to the TV with the correct connection of the video( yellow) , the red and white to audio inputs.
Oct 28, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
MY ORION TV KEEPS FLASHING PINK AND I HAVE FUNNY LINES ON THE SCREEN CAN ANY ONE HELP THANX ANT
Ur Tuner signal board might be dead,need replacing or the incomming coalax signal cable is damage.Take ur tv to another location plug in another incoming coalax signal cable,if u have the same problems after the tv is on about 20 mins or less.Than ur Tuner board is the cause,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.If the incommnig coalax signal cable is the problems,call ur cable companny.
Apr 28, 2010 | Sanyo 42 in. LCD TV
Actually it a lnt5271f, but...
Your cable line coming to the house may be fine, but each device has a section of cable running to it separately. This will be coming from one or more splitters leading from the main cable. Follow the cable line that leads to your new problematic TV, to verify that both ends of the cable are firmly connected.
If you use a cable box then send the signal to this TV, be sure you have the cable/cables correctly and firmly attached/seated in order to get the full signal strength.
Also make sure that the cable is sound and not damaged or frayed in any way from end to end.
Jun 09, 2008 | Televison & Video
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
Ps3 is messing with my tv signal
it's usually a grounding issue with yoru cable connection. disconnect your coaxial cable from your tv and you'll lose your humming and lines.
Apr 08, 2008 | Sony Playstation 3 (PS3) Console
Blue Vertical Line
sounds like a panel defect or a loose ribbon cable, but more than likely it's the panel itself
Nov 17, 2006 | Daewoo DTS42 42 in. HD-Ready Plasma...
Syntax Olevia 226T 26 in. LCD Television Logo
119 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
