Question about Seiko Table Clock With Alarm
Stopped working. New batteries will not let it start. Back will not come off. ref: qej308g cat. 34708    Tel #610-649-7047
          Henrietta C. Klein
0 characters
1 Points
New Gucci watch is not running, will taking off the plastic film with the red strip on the back make a difference.
That decal/sticker is usually only an indicator of a un-worn watch.
The only thing that will turn the battery on is pushing in the STEM.
If it does not run then... your battery SHELF LIFE has been
exceeded... Time to get a new battery
Gucci offers a repair service for Gucci products purchased from, ... Watch Repairs* East coast: GTS 50 Hartz Way Secaucus, NJ 07094 tel 1.866.692.8244
Gucci Gucci
Dec 14, 2015 | Gucci Watches
How to repair a fur real white cat from 2011. Put in new batteries, but will not do anything. The springs that hold the batteries look rusted.
If the springs are rusted then you've got moisture inside the watch and it probably either needs a new motor or needs to be serviced to remove the rust.
Dec 21, 2013 | Hasbro Fur Real Friends Kitty Cat White
Bvlgari sd 38 l 2161 is this watch battery or automatic brand new as gift not working email
If the watch is automatic, it usually says so on the face of the watch.
I have looked at their web site and most of the models are automatic, although a few are manual or quartz.
If it is automatic, then you can wake it up by swinging it from side to side a large number of times. If you wear is daily, then it should keep working satisfactorily. If it is not used for 2 -3 days, then it will stop and you will have to shake it again to start it.
If it is a manual watch, then it can be wound up using the crown (winder).
If it is quartz, then these are usually working when sold (is the crown pushed in?) and if it doesn't work, it might be replaced under warranty.
If you need further help you can contact them and tell them your problem.
Jul 19, 2010 | Watches
The watch has stopped working reset to 1.1 date new battery?
It sounds like it. Take it to a local dealer who will change it for you.
Feb 18, 2010 | Casio Atomic Solar G-Shock GW1210A-1AV
Tel-Time watch talking how to set time blind person watch
My sister is blind and owns a Tel Time watch with two buttons. I just had the batteries replaced but the time keeps going back to 12 a.m. How do I set the darn thing?
Dec 31, 2009 | Timex Watches
Starts and stops
take and have it cleaned and oiled
Aug 05, 2009 | Columbia Elkhorn Countour Watch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Watches Logo
59 people viewed this question
Top Seiko Watches Experts
Dan Castro
Mental Breakdown
Level 1 Expert
Level 1 Expert
Are you a Seiko Watch Expert? Answer questions, earn points and help others
