Question about Kitchen Ranges
Oven takes 5 minutes or more to ignite - Kitchen Ranges
  • 5,911 Answers
If this is a gas oven, more than likely you have an igniter that has become weak and is beginning to fail. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Just because an igniter glows, does not mean it is good. It should only take about 90 seconds or less for the oven to ignite.
Read through the link provided and let me know if you have any questions. I hope this helps you solve your problem.
Posted on Jun 16, 2009
Oven often takes half hour to heat up
it is the problem with your gas supply jet.
well the jet could be blocked
check the gas jet and open it with a pin or needle
Feb 01, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
My gas burners do not light for up to 5 minutes. I always get a spark on every burner from the automatic pilot when I turn it to light but it can take from 1 second to 5 minutes to light.
The ignition spark needs to jump from the electrode tip to a piece of bare metal on the burner. Make sure the burner area is clean and dry.
Nov 01, 2010 | Electrolux Microwave Ovens
Igniter will heat up (glow), and oven may or may not light for 5 minutes (with igniter glowing). After heating, and stabilizing...once the oven starts to cool, igniter will glow again, and may or may not...
The stove should not take over 3 minutes to light. Even if the ignitor is glowing it is impossible to really tell if it is ok or not. When the ignitor heats up it's resistance drops, this allows for the amp draw to get to 3.2 amps or better and that opens the bi-metal inside the oven valve. The oven circuit consists of a control to regulate temp, a safety valve, a ignitor, and a burner. Any open component and the oven will not fire off. If all the components have continuity and the ignitor is glowing, but no joy, I would replace the ignitor. Usually the ignitor gets dim when it is weak and it takes a long time to light off and you might even have to bump the stove and get it to come on. Replace that ignitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 02, 2010 | Ovens
Oven takes 3 or 5 min to ignite igniter comes
you may need tp replace the FFD in the oven.
Jan 02, 2010 | Kitchen Ranges
Bake oven does not light. Igniter glows for many minutes but no gas to oven. When I wrapped gas valve with hammer it lights!! When oven burner goes out when reached desired temp, it will not relight...
The igniter needs to draw between 3.6 and 4 amps to open the gas valve even thogh it is glowing the resistance may not be the same . Check the amperage and then replace igniter
Dec 14, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Oven and broiler won't come on
It's most likely the igniters in the oven. They cost about 40$ apiece and our oven has two. They are fairly easy to replace.
1) Turn off the electricity to the stove, either with a switch or your circuit breaker.
2) Remove grills, side support grills and oven base. They all just slide out.
3) Remove door to avoid breaking it. It slides off.
4) Remove old igniters, they are attached with two screws. Remove 2 wires from plugs. It might be necessary to lower the front base panel to get to the plugs - the panel is attached by two screws on the side of the panel.
5) Install new igniters, put the door and grills on and you're good to go.
The first time, it might take an hour to get used to your stove, but its really about 15 minutes of work.
Jan 13, 2009 | Viking VGSC306-4B Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
