Question about Garden
Toro commercial walk behind w/kohler 15 hp spits and sputters when put under slight load. Was working good before the local toro guys tuned it up!
  • 59 Answers
Try a new spark plug
Posted on Jun 19, 2009
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Toro 5/24 snowblower will start but dies when i start throwing snow
Had the same problem with my toro blower 5/24 and small engine guy told me that there is a screw underneath the carburator adjust it out (left) about a quarter of turn. I did that and the blower ran good for awhile but it is starting to run rough again so I think I will take it in and have it tuned up. It sounds to me like a fuel delivery problem, could be some gunk in the carberator. TW
Jan 06, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Hydro pump reserve blowing out fluid on Toro z- master
is this all after the parts where changed and while bleeding out the air put the system under vacuum
May 13, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Where is the model/serial numbers found on a toro self-propelled lawn mower found?
On the rear of the deck, usually under the black plastic shield. Lift the shield (like you were putting on the bag) you should find a white sticker with black lettering. The model number is 5 digits. If it is a commercial type model, sometimes they hide the sticker behind the handle name plate.
Good luck
Sep 10, 2010 | Toro Lawn Mower With Toro Power Tools
Fuel flow problem
Maybe the main jet has something in it. I once found a fir needle in one. Don't ask me how it got there.
Jun 13, 2010 | Toro Walk Behind 30678 Commercial Walk...
I have an old Toro proline 52 inch commercial walk behind 18hp kohler and I don't know how to put the transmission belt on right.
Simple rule. V of the belt goes in V pulleys
The back of the belt goes on flat or idler pulleys .
It may take several tries but I am sure you can figure it out.
Sep 10, 2009 | Garden
6.5 toro walk behind self propell b&s engine. self propel does not work
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
