Question about Canon Pixma MP500 All-In-One InkJet Printer
Paper guide broken
The paper feed guide broke off the back of the printer so when the paper feeds it gets jammed in the printer
  • Anonymous Mar 13, 2014
    how to put paper guide back on printer
  • 518 Answers
IF YOU DON'T WANT TO PAY OUT FOR A NEW PRINTER, TRY PLACING THE PRINTER UP AGAINST A WALL AND THEN PUT THE PAPER IN.
Posted on Jun 16, 2009
Paper jam door - I cannot open this no my HP 8250.
Turn off the printer, then unplug it from the power source. Clear the
printer of any paper that may be obstructing the paper path. Remove the rearaccess door. Gently remove the jammed paper from the printer, then replace therear access door.
Remove the rear access door to clear paper jams.If you cannot remove all jammed paper from the rear area of the printer, tryremoving paper jammed in the middle of the printer by opening the paper jamdoor located inside the top cover.
Open the paper jam door to clear paper jams in the middle of the printer.Plug the printer back in and turn it on.
In case of any doubt go to the following link and act accordingly
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386753&lc=en&dlc=tr&cc=us&product=443024
Sep 25, 2011 | HP Photosmart 8250 InkJet Printer
Pper jams
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Timing, jams or prints off bottom of page
Hi hotpress:
Try these steps.
Print transfer jams
1.
If a piece of paper is trapped in the paper preheater, try pushing out the paper by
inserting a stiff piece of cardstock into the paper preheater.
2. Using diagnostics, test the paper preheater sensors. If the test fails, replace the
paper/drum heater assembly.
3. Check to see if the upper feed roller drive belt is broken or slipped off of its pulleys. In
such a case, the upper feed roller does not rotate when the lower feed roller rotates.
4. Check that the feed rollers rotate smoothly and that the front cover is fully closed and
seated.
5. Check the paper-eject path for obstructions. Ensure no small pieces of paper are
trapped around the stripper fingers or rapid release guide.
6. Ensure that the transfix roller rotates during the transfix process. See SF168 and
SB467.
7. Test the sensors in the paper path. Look for damaged or non-operating sensor flags.
8. Check the transfix solenoid and its cam. Ensure they operate correctly and are properly
lubricated. If lubrication is needed, apply a dab of grease to the contact point between
the cam and the latch and the cam and the cam-advanced spring. Refer to
"Lubrication" on page 6-177.
9. A stripper finger, or rapid release guide, jam can occur because of broken teeth on the
small section of the back-side of the compound gear. The root cause of this may be also
be due to a lack of transfix cam grease. If you find broken teeth on the compound gear,
check for proper lubrication of the transfix cam. Be careful to ensure that no grease
touches the Y-axis belts. If the belts get contaminated with grease they must be
replaced. wipe off any excess grease to prevent it from dripping onto the belts.
Hope this helps
May 23, 2009 | Xerox Phaser 850 Printer
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Paper won't feed and get's stuck
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
Good luck..
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 30, 2008 | Dell 924 All-in-One InkJet Printer
Lexmarkx73 Won't feed paper through while printing
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Paper jam
Sounds to me like the paper jam switch is broken. Open the back door and look at the center where the paper feeds between the rollers. There should be a small plastic switch actuator sticking up, it probably got broke off.....
May 02, 2008 | Dell 1700 Laser Printer
Paper jam
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Mar 24, 2008 | Office Equipment & Supplies
Paper fed
Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 14, 2007 | HP LaserJet 2420 Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
