Question about Speck Pumps Impeller. 3/4 Hp, S.F. 1.0, E90
Speck Pump Model E90 has very little pressure when vaccuming pool
Need to have pump replaced with appropriate parts, is there a website that has the spare motor/pump I would need?
    Scholar:
  • 34 Answers
While I can not personally vouch for this company, they do stock speck parts.
http://www.poolpartsonline.com/m-44-speck.aspx
You will most likely need part # 2920741271 - O-RING (strainer tank) It's the o-ring that sits underneath the strainer lid and is most likely cause of your weak vac pressure. Make sure when you replace it, you use a good silicone based lube. It will help the lid seal better and prevent the o-ring from deteriorating faster if you used a petrol based lubricant.
Posted on Jul 17, 2009
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
My pool pump is making a screeching noise
Chances are you either have something stuck in the impeller (not likely), or your motor bearings are worn out. If the latter is true, you are about to lose the use of your motor.
Depending on your motor, you may be able to have the bearings replaced. Otherwise, you may be looking at a new motor.
When the bearings on mine were going out (mine are non-serviceable), I just continued to run the motor til it completely failed. Then I replaced it.
If you are the "do-it-yourself-er" type, it is much cheaper to order a new motor online and change it out yourself. Takes less than 30 minutes. Be sure to replace the shaft seal when you change out the motor. I replaced my Sta-Rite Duraglas (A.O.Smith) motor and seal for $150.
Hope this helps.
Jun 15, 2013 | Speck Pumps Pool & Spa
My pump is making a screeeching sound
Most likely bearings. They will eventually break down. You might find someone in your area to replace them ... I suggest you find a back up motor.
Jun 15, 2013 | Speck Pumps COMPLETE E90II PUMP Part...
My new ecotouch pump will not pump. It is a week old and the problem has occurred today. The lights on the pump indicate that it has power, there are no error flashes, but the pump does not switch on. When...
I would check the correct voltage is being fed to the pump (220-230v). Otherwise call this guy at the company, he was pretty helpful to me. Remember you have a 2yr warranty.
Ed
Chris Calise ? Manager - Pool Sales
Speck Pumps ? 8125 Bayberry Road Jacksonville, FL 32256
Phone: 904-739-2626 ' Fax: 904-737-5261
Toll Free: 800-BADUJET (2238538)
Email: c.calise@speck-pumps.com
Jul 02, 2011 | Speck Pumps Badu Ecom3 Variable Speed Pool...
MY E90 III SPECK POOL PUMP IS LEAKING BEHIND THE IMPELLER. WE JUST REPLACED THE HOUSING O RING. PLEASE ADVISE A FIX
Thank you for posting your question here on Fixya.com.
Replace the mechanical seal located behind the impeller along the motor shaft. Half is on the impeller and half is in the seal plate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 28, 2011 | Speck Pumps Pool & Spa
Trying to replace a 4hp motor on a speck pump but can't remove the impeller, also, how is the seal plate attached? I've worked on several 3/4 to 3 hp pool pumps but this one is a first!
Id be happy to help if you could tell me what model speck pump you are working on.
There is just not enough information here.
Once you have the model, you can contact me @: adamh@newconceptchem.com for further assistance. I will give you the website for all the speck manuals incase you need it as well.
http://www.speck-pumps.com/html/usa/download_pool.html
thanks,
adam
if this post has helped you, please take the time to vote positively for me on this site.
Oct 16, 2010 | Speck Pumps Impeller 1hp Full1 12hp Up...
I have a 18" Intex pool and I need directions for hooking up the pol's vaccum. The pool was given to me.
hi
the tricky part is to avoid air from coming into the vaccum pipe and from there to the pump .
1. the first thing you got to do is fill the pipe with water .you can do that easly by putting the vaccum pipe next to the outlet water exit while the pump is working till you see that there is no more air inside the pipe .
2. connect the pipe with the cone to the skimmer , at this stage you might get some air inside the pipe but don't worry .
3. once all part are connected and the vaccum head is in the water activate the pump and open the top screws on top of the pump and the filter to realese the air that might have entered the pipe .
once the air is out and the vacuum works close the screws and you are ready to go .
enjoy
Jul 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Speck Pumps Impeller. 3/4 Hp, S.F. 1.0, E90 Logo
461 people viewed this question
Top Speck Pumps Pool & Spa Experts
k24674
Gil Shultz
Jay Finke
Jay Finke
Are you a Speck Pumps Pool and Spa Expert? Answer questions, earn points and help others
