Question about Xerox DocuPrint N40 Laser Printer
Changing the language display on xerox n40 printer
I have a xerox n40 printer, but the display has somehow gotten changed to a different language. (Russian I believe). I have no manual for this. How to I change or reset the language display. Thank you!
  • 518 Answers
IF YOU CANNOT READ RUSSIAN, THEN MAY I SUGGEST ADD AND REMOVE, DELETE SOFTWARE FOR THIS PRINTER AND THEN REINSTALLING THE SOFTWARE, IT SHOULD THEN ASK YOU WHAT LANGUAGE YOU REQUIRE.
Posted on Jun 16, 2009
I have dymo 450 printer who can i change languge
https://www.manualslib.com/manual/414419/Dymo-LabelwriterAnd-174-450-Duo-Label-Printer.html?page=94
Dymo LabelWriter 450 Duo Label Printer User Manual Changing The Language...
Quoting from the manual at the web link shown:
Changing the Language (Windows Only) You can change the display language for the DYMO Label software so that you can work
in a language that is most familiar to you. Changing the language only affects the text and messages in the software. Features available in the software are determined by the operating
system locale.
To change the display language
1. Choose Preferences from the Edit menu.
2. Select the General tab.
3. Under Language, select the language you want.
4. Click OK.
The language changes immediately without restarting DYMO Label software.
Apr 08, 2018 | Dymo Office Equipment & Supplies
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
Dec 07, 2010 | HP LaserJet 4500 Printer
How do I change the language on my new J4580 machine
Hello
Thank you for using FixYa for your problem.
Try this;
Changing the language on the HP All-in-One displayFollow these steps to change the language on the All-in-One display.
  1. Press the Setup button (c01361401.gif).
  2. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Basic Settings, and then press OK.
  3. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Set Language, and then press OK.
  4. Use the arrow buttons (c01185108.jpgc01185072.jpg) to scroll through the language options until the preferred language is displayed.
  5. Press the numbers on the numeric keypad that correspond to the appropriate language displayed on the control panel display.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next language. If a selection is not made withintwo minutes the setup menu exits and the language/region remainsunchanged.
  6. Confirm the language choice.
    • Press the number corresponding to Yes to confirm the selected language.
    • Press the number corresponding to No to select a different language.
  7. Aftera language is selected, a screen is displayed for region selection.Press the numbers on the numeric keypad that correspond to theappropriate region.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next region. If a selection is not made within twominutes the setup menu exits and the language/region remains unchanged.
  8. Confirm the region choice.
    • Press the number corresponding to Yes to confirm the selected region.
    • Press the number corresponding to No to select a different region.
Please Rate my solution or reply for another answer if still not going
Thanks
Richard Scott
Technical Support
Nov 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
Ibm info print 40 fuser 90h3567 same as xerox n40 fuser 109r486
Xerox put identity chips into their consumables and I presume IBM do the same which means even if the fuser is exactly the same your printer is going to reject it as a incompitable part
Sep 08, 2009 | IBM Infoprint 40 Laser Printer
My printer for some reason is in spanish....how do I change it back to English? Also the screen is messed up...sometimes it is dark and other times it is too light to see anything...without anyone...
You have 2 different issues. First let me address the dark and light screen. There is a known problem with that machine screen. Call 1-800-835-6100 and Xerox will send you a free replacement.
Here is how to change the language.
To select the default language on the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Control Panel Setup], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Language], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required language, and then press the [OK] button.
  5. Press the [Back] button, located to the left of the 'Up' and 'Down' buttons, three times to return to the Main Menu.
To select the default language using CentreWare Internet Services (CWIS):
  1. Open an Internet web browser on the workstation.
  2. Enter the IP Address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on [Properties]. The Properties window will be displayed
  4. Click on the [General] folder on the left, and then select [Printer Defaults].
  5. Under the User Preferences section, select the language from the Set Control Panel Language pull-down.
  6. Click on the [Save Changes] button.
  7. Click on the [X] in the upper, right corner to close the window.
Dec 18, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560 - Changing Menu from German to English Language
If you are talking about the driver menu you have to delete and reload the driver with the english
Jul 22, 2008 | Xerox Phaser 8560MFP Laser Printer
HP PSC 1610 prob
hmm okay hun
how did they change it from the printer
or from the comp?
Jan 07, 2008 | HP LaserJet 1020 Printer
Asterisks in display
had the same problem: took the tray away and found a sheet of paper in the printer not alawing
the tray sensor to work properly!!! after that the prob was solved.
Sep 25, 2007 | Xerox DocuPrint N40 Laser Printer
Xerox DocuPrint N40 Laser Printer Logo
98 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
