reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
I can help you with your URC-3021 Universal Remote Control issues.The code for Sansui TV's is: 0463.For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.I hope that helps._______________________________________________One For All URC-3021 ManualOne For All URC-3021 Code ListOne For All URC-3021 Code EntryOne For All URC-3021 Code SearchOne For All URC-3021 Reassign Key
Sansui tv share same codes with: Magnabox, phillips, Sanyo, Sears, Sylvania, Teac, Toshiba, sampo, Symphonic, Zenith.
Try codes from these manufactures using your remote code table.
what kinda off provider!! there is a web sight go under universal remotes and look up the remote you have there should be a code for your remote this should help!!!
only a sansui remote can replace itself, sansui is a great company and prides itself on being unique, you would have to order a remote directly from the maker if possible to use all the function of your unit. even if u get a universal unit to program it probably won't control all of ur function.
