Question about Microsoft Natural Keyboard PRO. Two USB Ports 19 hot keys for instant access Supports Win XP 2000 ME... (B6100002RETAIL)
Bmw 5 series e39 heating fan
The heating fan on my bmw e39 has packed in.Any idea what could be wrong with it?Can hear noises when i change controller but fan will not work on any setting?Fuses are ok but fan fails to activate!Any ideas?
    Problem Solver:
  • 13 Answers
Re: bmw 5 series e39 heating fan
Posted on Feb 20, 2009
Re: bmw 5 series e39 heating fan - Microsoft Natural Keyboard PRO. Two USB Ports 19 hot keys for instant access Supports Win...
Check your blow motor.
Posted on Jan 13, 2008
0 characters
3 Points
P305 gets to hot
Turn off the laptop, close the lid, flip it upside down and rest it on a flat surface.
Locate the cooling fan, which is under the vents on the bottom of the laptop.
Spray the compressed air can inside the vents for 5 to 10 seconds.
Change the air direction until all the dust is cleared.
check you CPU make sure its securely seated and has thermal grease
hope this helps
Oct 09, 2012 | Toshiba New Satellite P305 series S8825...
Need to change Apire 5732z from Spanish laguage to English, kindly assist
To install a different language - Multilingual User Interface (MUI) - you need to have Windows 7 Ultimate.
Anytime Upgrade to Windows 7 Ultimate
Type Anytime Upgrade in the Search programs and files box in the Start menu and click on the Windows Anytime Upgrade icon. From there, you can buy an Anytime Upgrade to Windows 7 Ultimate. Then your can enter your Anytime Upgrade product key and perform a simple upgrade to Windows 7 Ultimate so you can install a different language.
If you are in Australia, Belgium, Canada, France, Germany, Italy, Japan, the Netherlands, Spain, Sweden, Switzerland, the UK, and the US you can use Anytime Upgrade. If not you will need to buy Windows 7 Ultimate, or buy Windows 7 in the language you need.
Install Language Pack in Windows 7 Ultimate
1. Start -> All Programs --> Windows Update --> Optional Updates.
2. Open optional Updates and go to the section Windows 7 Language Packs.
3. Tick the Language Pack you want and hit OK
4. Proceed with Install Updates
5. Depiction of Windows 7 downloading a Language Pack
6. Automatic install initiated after download
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
Feb 28, 2011 | Acer NSK8458AN Keyboard
I hear the sound from dell touhpad i 'd like to stop this sound
The sound is probably a fan that is damaged or bent (from heat) and it is making a whirring or screaming noise. You will need to replace this before it damages the system. The system depends on the fan so that it can stay cool. An overheated system will destroy the hard drive, motherboard and any other components around it over time.
Purchase a can of air and blow it inside the air vents of the laptop. This will remove any dust that has gathered.
Touch the bottom of the laptop to see if it is extremely hot. If it is, then the overheating has already begun.
Changing the fan out can be overwhelming because you have to open the laptop up. There are you tube videos and picture, step by step instructions on-line.
The fan cost less that $5.00
Sep 21, 2010 | Dell F3534 Touchpad
Is there a on off button for the fan as my laptop seems to be over heating?
Usually the fan is controlled by the laptop. It comes on when it gets too warm. If you cannot hear the fan running from time to time, try blowing out the fan ducts with a can of compressed air. Also, laptops seem to generate a bit of heat due to there closed in parts. Also don't operate the laptop on anything soft like a blanket, or pillow or even your lap. (I use a large hardback book under mine)
Mar 18, 2010 | Acer NSK8458AN Keyboard
Hi Mouse Not responding
common problem of either the surface or the mouse, get replaced with a standby..!!
however, to b in safe hands, check the following:
the Hardware part:..
1) see if the ram(s) is loose/ clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink*** fan..resit/fit it tightly in position..if necessary change the fan..
5) on main/motherboard..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i preferavg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..
3) download n run Startup Control Panel..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..
6) disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->start up n recovery->(uncheck on the) Automatically Restart;
b) 'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
contact ur system admin/vendor....
Nov 17, 2009 | Laser Logitech O - V450 Nano Cordless ...
Need to upgrade my usb ports to 2.0 for my laptop
Sorry to say that there is no way to upgrade usb 1.1 ports to usb 2 as it is related to the chipset connected to them. Windows service packs do not help in this case where it is hardware to be changed. Try looking for a PCMIA card that has usb 2 ports on.
Feb 15, 2009 | Gateway Solo 9100/9150 Series Laptop...
No audio sound after installing the keyboard software
when you loaded the software for the keyboard, the buttons on the keyboard for functions will be active, have you made sure that the mute key on the keyboard is not pressed 'on' to mute the sound?
Nov 18, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard click
i think u will hear the noise whn u pressing shift ,ctrl,and alt keys continusly na..these keys r called sticky keys.....pls press these keys 5 times continusly thn one window will come in that window thr is a option called turn off sticky keys pls tick the box u can remove the noise k
Sep 19, 2008 | Logitech 967437-0403 Keyboard
It doesn't turn on!
If your Macintosh computer won't turn on, here's how to troubleshoot it. Please keep in mind that although your computer may display similar symptoms that prevent it from showing video, this article discusses what to do if the computer won't turn on, meaning that when you press the power button:
  • You don't hear a startup chime
  • You don't hear any fan or drive noise
  • The power button or power indicator doesn't light up at all
If your computer doesn't display any video, it may display one or more of these similar symptoms when you press the power button:
  • You may hear a startup chime
  • You may hear fan or drive noise
  • You may see the power button or power indicator light up
If any of these conditions occurs, see the Troubleshooting: My computer has no video article instead. If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU or PRAM.
    • For a portable (iBook or PowerBook), click here for instructions.
    • For a Mac mini, click here.
    • For an iMac, click here.
    • For a Power Mac, click here.
    • For a Mac Pro click here.
    • For a MacBook or MacBook Pro, click here.
    • For any other computer, click here for instructions on resetting the PRAM.
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord. You can get a replacement cord for some models here.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to your local Apple Store or Apple Authorized Service Provider (AASP) for diagnosis.
Feb 22, 2008 | M-Audio US85100 Keyboard
Sony Vaio PCG K115M keyboard problem
Hi, its easy to fix. you have your keyboard layout set to US Layout, ie americans have a couple of keys in reverse from ours. All you have to do is this Windows XP Start, Control Panel, regional & language settings, change all US Settings, in there to UK British, And it will fix your problems :-) if its windows 98/ME ETC start, control panel, Keyboard, and change the US Keyboard setting to UK British, u usually have to set it twice, ie select uk, apply it, then do it again before it changes... If you dont get it sorted will guide u though it just email me.. All the best John
Jan 31, 2007 | Sony Vaio PCG-N505 Series Laptop...
Keyboards & Mice Logo
6,949 people viewed this question
Top Microsoft Keyboards & Mice Experts
micky dee
Are you a Microsoft Keyboard and Mice Expert? Answer questions, earn points and help others
