Question about Dell Dimension E520 PC Desktop
No display on the Dell Dem 520
I am working on a Dell Demn 520 and the screen is black.I start the system the lights come on but i get nothing on the screen. I tried 3 different monitors, I replaced the Graphic card and I even took out the CMOS battery and the screen is black. The monitor does not even turn green when the computer turn on. I don't even get the bios screen to come on. Also I took out the mem. All i get with the mem out is the beep error code for no mem.
  • 518 Answers
IT SOUNDS LIKE HARD-DRIVE FAILURE, TRY REINSTALLING THE OPERATING SYSTEM, BUT IF IT DOES NOTHING THEN REPLACE THE DRIVE
Posted on Jun 16, 2009
  • Genie Plus
    Genie Plus Feb 26, 2011
    Colinmns nothing is coming on his screen even the BIOS how will he install an OS....???
    Problem can be from least to worst : CMOS battery/ Powersupply / memory/ graphic card/ motherboard/ CPU.
    Simple test : first unplug the power cord, remove the battery, clear the CMOS, unplug the Power Supply completely from the motherboard/ CPU/ HDD/ DVDRW etc, ..leave all this unplug for 30mins ...
    Now replug ONLY the Power Supply to the Mboard CPU but don't put the battery back for now and don't forget to put the CMOS jumper back. If the computer start then it might be a battery issue or Power Supply because of a static current.
    Else it might be the memory / Motherboard/ CPU/ graphic card...
    Memory fault : usually do beep sound
    CPU fault : usually fan don't turn 'not always depend on mboard'
    Graphic card : fault is HDD is like loading windows but nothing on sreen
    Hope this help
Black screen but i didnt hear any beeps
Dear frnd,
its looks like Operating system problem. some times its happens that you power on and its display nothing except a black screen. you need to re-install the os but before it you have to confirm that your display screen is working. for that check the display in dark place so that when you power on its screen going to slightly white if its happens than its screen is ok if its doesn't than you have to change display screen cable inside of the laptop.
Jan 15, 2014 | Dell Inspiron Mini 1012 Netbook...
Power turns but screen stays black no
Try anouther screen . turn off, unplug, hold in the power button for 30 seconds, release plug in and try agin. this sometimes reset the capacitors on the board. can you hear the sound as it starts up also is there any lites on the back around the power supply?
Oct 18, 2013 | Dell OptiPlex Computers & Internet
I have a XPS M1530 the screen is black I press the power button for a second it stay on everything lights up sounds and feels like its on gets warm but nothing on the screen Itrying everything taking out...
You either have a Video Card problem or an issue with your LCD Screen.
Does it every post anything to the screen? If nothing ever posts on the screen when you hit the power button and it will not do anything with an external monitor, then your Video Card is bad. I wonder if you have the Nvidia Graphics Video card on your system?
If it seems like the laptop booted up all the way (you hear fans running, hard drive spinning, see lights) but the screen is black then try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell Computers & Internet
Had bluescreen a number of time, but laptop always booted up again. However i now have a black screen and nothing will boot up,even tried the dell recovery disc, but nothing. Any ideas?Thanks
Dell includes a series of tests for a system's hardware into the BIOS called the PSA+ Diagnostics. You can run these tests even if the system lacks any media (hard drive, CD drive, etc.). To launch the PSA+ Diagnostics on this system, perform one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dell™ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • If all tests pass you will need to re-install the operating system software.
Sep 01, 2011 | Dell Inspiron 1501 Notebook
Getting orange flash light instead of green stable light on my dell optplex 520 and 745 what should to solve the problem
replace the power supply with a known good one. If that doesn't solve the problem then the motherboard is bad and would need to be replaced.
Jan 15, 2010 | Dell OptiPlex 520 PC Desktop
I have a dell inspiron 6400 and im getting a black screen once the dell logo comes up and windows xp loads...I see no icons or nothing..just a black screen
it sounds like your display backlight has gone bad. If your handy you can get a new display. If you are really good you can replace the back light.
Nov 07, 2009 | Dell Inspiron 6400 Notebook
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Black screen sometimes, system restore not working, remote assistance,
Did you try reinstalling the video card and display drivers?
What game was installed and how many days after installation this problem appeared?
Jun 04, 2008 | Dell Inspiron XPS M140 Notebook
Ps3 not reading games
the same thing happend 2 me yesterday have you still got your warrenty if so i suggest calling sony mine done the same thing plus the same day after stoped reading any disks wt so ever i was on a demo and after playing i went to quit game and the screen was jus black wid 2 stripes n sayin please wait then did nufin until the system restarted its self :S:S bt i called sony today n told dem n they sending me a new system exchanging mine on monday its thursday today dats gd :) so jus call dem up hope it gets sorted
Feb 21, 2008 | Sony Playstation 3 (PS3) Console
Dell Dimension E520 PC Desktop Logo
231 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
