Question about Refrigerators
I have ice build up in rear of fridge compartment
  • 72 Answers
You need to install a drain heater, the kit comes with directions, all you will have to do is thaw out the ice and the drain tube and follow the instructions.
Posted on Jun 16, 2009
The fridge has stoped workingbut the freezer is fine
if it starts working ok after the defrost then you might find it will build up ice again.
There might be a fault with a small device called a thermister that senses the ice build up for the defrost controller.
What most likely is happening is the ice build up freezes the fan that blows the cold air to the fridge compartment.and around the freezer.
May 14, 2017 | Bosch KGU6655
Freezer is fine, but refrigerator side is warm and NOT cooling. Door was not left open, etc . Top interior light was not coming on and was extremely hot to the touch, but is now coming on (did not...
this problem is usually caused by excessive ice build up on the evaporator coils.There also a chance that the evaporator fan in the freezer compartment is not working this is how your fridge gets cold.if there is ice build up on the evap coils there may be a problem with the defrost heater or timer.there is a door damper located in the rear of the fridge compartment that needs to be check for anything that may be obstructing the operation of the door.
Oct 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
FP E381T, lights won't stop flashing, fridge not cooling properly
There is another fan to draw air into fridge compartment- access via fridge: remove back panel (long plastic cover- just clips off). Remove control housing (again, just clips off- careful of wiring though). Fan is located up in this channel between fridge and freezer compartments. However, from what you are describing, I think you have a blockage in the freezer drain, causing a build up of ice in the freezer which blocks the air flow to fridge.  To check, remove rear panel of freezer (clips off- you need to press down two clips at top of panel, they can be tricky to get off!!). Disconnect fan motor wiring by unclipping plug connection, and remove sensor wire(white wire) so panel can be removed completely. Now have a look in the trough underneath the evaporator, and check for ice buil up- there should be no ice in this trough. If it is iced up, you need to defrost ice and then pour some water in the trough and see if it runs away. In the middle of the trough there is a small hole where the water should run down and away to collector tray at rear of fridge- if this hole is blocked, water won't run away, so builds up and freezes and blocks air flow to fridge. If hole is blocked, poke a wire down to unblock.
If in doubt, call in the experts- F+P fridges can be a bit fiddly getting apart, as everything clips together ( I worked for F+P for 10 years, and I still sometimes have problems getting panels off easily!!)
Good Luck!!
Mar 10, 2010 | Fisher Refrigerators
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
Ice build up in freezer compartment until water flows onto floor.
Hi, Is this a wwhirlpool brand fridge?
The drain is plugged in the freezer section. If I could get model #,I can get you ezact instructions.
If the floor panel in the freezer has screws holding it in, remove the fllor panel. Now you will need to remove the rear panel inside the freezer as well.
If this is a Whirlpool brand, there is an after market drain heat strip that you will need to add to the defrost heater.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Refrigerators
Firdge not cold on a combi fridge freezer
possible ice build-up behind the inside rear panel. you have to remoive panel defrost ice with hair dryer then replace the heater/defrost cable. the job cost around 125. for an appliance tech to fix it hope this helps...
Sep 22, 2008 | Refrigerators
Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Aug 25, 2008 | Fisher and Paykel Active Smart E522B...
Bosch classixx frost free fridge freezer
i cannot set the temperature from -12'o to -24'o
Jun 23, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
