Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Series 90 Kenmore washes but won't rin...
By jmiller366 on Jun 16, 2009
I have the Kenmore series 90 Plus HD washer and it will agitate but nothing after the wash. It will not drain, rinse or spin. Washes/agitates, but then stops after cycle and water remains in tub.
Checked the coupling and it is fine. Familiar with this and was hoping that was the issue because I have replace it before. This is model# 110.28932790stock# 28932
The reset worked a couple of times on the water level after I opened & closed the lid, now nothing. Agitates, then sits and won't go to next cycle.
Comments:
Jun 17, 2009
- jsrock516,
I wanted to write you a quick note and say a huge thank you! The link to the instructions you posted doesn't work but I should be able to get the switch installed with no problem. I truly appreciate you taking your time to offer this fix! Many, Many, Many.....Thanks from me & my family!
jmiller366
Best Solution
posted on Jun 16, 2009
Helpful)
jsrock516
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 6796 votes
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Comments:
Jun 21, 2009
- Sorry about the link not working. I'll try poasting it here again:
If the link still does not work, you can go to my profile and access the link under my "Tips and Tricks" for replacing a lid switch. If you need any further assistance, please let me know.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
my ge whdsr209dww ...water is coming out of (i assume) overlflow tube that is located in side on the... (More)
Answer
door will not lock gives dr code I checked the door pins they are not broken and door is closing all... (More)
Answer
my fabric softner won't dispense into the washer during the rinse cycle. still there when wash is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
