My washing machine stopped in mid cycle and no power appears to be going to it. We drained the water and filter found a bobby pin and removed but power won't come back on. Is there a reset button?My washing machine stopped in mid cycle and no power appears to be going to it. We drained the water and filter found a bobby pin and removed but power won't come back on. Is there a reset button?
We turned the fuse off for 30 minutes but still no power to the machine. Is there no re-set button?We turned the fuse off for 30 minutes but still no power to the machine. Is there no re-set button?
This machine is by far the worst I have encountered for finding parts. I just went through 18 pages and there was nothing that looked like a control panel. Most sites has a Parts Schematic by the area of the machine the parts are in.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and
then doing a soft reset. The boot screen will popup with a message “To
perform a clean reset, which will clear all data in memory, press the
[Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
I'm sorry but the only way to recover the device would be a hard reset. You will loose any user files on it and the device will revert to it's factory default state.
To do this there are 2 ways depending on your operating system. For a default stock hx2490 with wm 2003se :
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit. After the screen gets blank, your device should hard reset.
For an upgraded wm 5 device press power, calendar and mail buttons while inserting the stylus into the reset hole.
Both of these should yeld the same results. If you don't get the right button combination, try it again.
How did you fix that? I have the same problem... looking for solutions...
