Question about Compaq Presario M2000 Notebook
Vertical White lines on the monitor
I have vertical white lines across my monitor when I try to turn it on. What should I do to fix it and NOT cost me so much?
Thanks in advance for your help! :)
  • 518 Answers
IT SOUNDS LIKE THE SCREEN HAS COME TO THE END OF IT'S LIFE, SORRY FOR THE BAD NEWS MATE
Posted on Jun 16, 2009
AOC vertical white line moving across the screen
I have dual AOC i2553ph monitors. One day I came into work and notice one of them had a single vertical white line moving slowly back and forth across the screen that looked like a scan or radar function. I reset the monitor from the OSD and all is well again. Use "Extra > reset" from the OSD on AOC monitors.
Jan 31, 2012 | AOC Computers & Internet
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Relisys vertical bars
Sorry this wont help you much, but may put you out of your misery trying to repair it.
The LCD panel has failed. In particular the driver tabs that connect to the physical panel have failed and there is no way to repair them.
The only soloution is to replace the entire panel, a cost that would be close to if not more then a new TV of the same size.
I would put it on Ebay for parts (powerboard, logic board etc), and use the money towards it's replacement.
Peter
Mar 25, 2010 | Relisys RLT1720 17" LCD Monitor
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Samsung monitor has white background with vertical color lines
if you have got access to another monitor try that it may be the computer or try another computer on the monitor hope this helps regards Jim
Apr 20, 2009 | Samsung Cell Phones
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Compaq Presario M2000 Notebook Logo
115 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
